MIMX8ML8CVNKZAB LPDDR4 interface
已解决
跳至解决方案
3,189 次查看
aprakashbaler
Hello I am using MIMX8ML8CVNKZAB I.MX processor in one of my design. In the IBIS model available on the website, ODT SUB models for DQ and DQS signal is having 40, 48 and 60 ohm impedance, and i want to know what is the ODT structure pull up or pull down or Thevenin. is can i get the full range of ODT available for the device.
and one more thing observed in the IBIS model is pins  AA4 and AA5 mentioned as a differential.
标记 (1)
1 解答
3,170 次查看
Rita_Wang
Recommend you to refer to our reference design and the IMX8MPHDG.
在原帖中查看解决方案
1 回复
3,171 次查看
Rita_Wang
