MFGTool error while writing boot.img
Anerudh
Hi all,
I am trying to boot an android prebuilt image on the IMX6Q board with the MFG tool. The android version I am trying to boot is android 6 (android_M6.0.1_2.1.0). I have placed the necessary image files inside the directory "C:\Users\rise\Music\android_L5.0.0_1.0.0-ga_tools\mfgtools\Profiles\Linux\OS Firmware\files\android\sabresd".
The tool gives an error while writing the boot.img and the MGFTool log file gives the following :
ModuleID[2] LevelID[1]: PortMgrDlg(0)--MSCDevice--Command Push(no file) excute failed
ModuleID[2] LevelID[10]: CmdOperation[0], current command executed failed, so SetEvent(hDevCanDeleteEvent)
Does anybody know how to solve this issue? What should I do to boot the prebuilt image in the board?
Rita_Wang
Are you using the NXP reference board or the board you design yourself? And have you using the proper images for your board?
