MFGTool Jumping to OS Image
beezle
I'm trying to update a SD-Card with MFGTool. My board is a i.MX6DL Sabre for Smart Devices.
Everything seems ok, however after loading U-boot, Kernel and Initramfs the process stops with "Jumping to OS Image". The SD-Card is Fat32 formatted.
I also never saw something in the Terminal.
SW6 is set to, 01000010. I have attached my cfg.ini and my ucl2.xml and the MfgTool.log.
I really don't know whats wrong and need help.
Thanks in advance.
Ingo
Original Attachment has been moved to: ucl2.xml.zip
Original Attachment has been moved to: MfgTool.log.zip
Original Attachment has been moved to: cfg.ini.zip
beezle
Sorry, that was my fault. :smileyblush:
Everything is ok now. I have not realized, that there are two different MFGTools for MX6Q and MX6DL available.
Thanks.
Ingo
beezle
Thanks.
Ingo
