Hi, i want to use mfgtool to get image from my device.My device use emmc not sd card.
The mfgtool put kernel and uboot to memory and run. And i have succeed to burn image to my device.
And now i want to get the image back to make a factory image.Is it possiable to use dd command make image from boot to pc only use mfgtool.I find there is command pull but no enough information about pull and dd command.
Thanks!
