MCUXpresso SDK Compatability
1,554 次查看
paul_katarzis
I would like to develop some software for the general purpose Cortex-M4 on the i.MX8QuadXPlus. The chip I am using has the ID PIMX8QX6AVLFZAA and is mounted on a custom board. Is the version 2.5.1 SDK for MIMX8QX6xxxFZ compatible for building software with this chip I am using?
1,357 次查看
joanxie
MCUXpresso SDK is for imx8X mek board, do you mean you develope customized imx8x MEK board with PIMX8QX6AVLFZAA?
1,357 次查看
paul_katarzis
Hello Joan,
We are not using an MEK board. The chip is mounted on a custom board designed and fabricated internally by our company. The chip on the board I am developing on has the ID PIMX8QX6AVLFZAA. When I tried to build an MCUXpresso SDK, the closest device I could find was MIMX8QX6xxxFZ. I don't know how to properly compare the device IDs to check for compatibility.
I know many of the examples are configured to run on the MEK, but what I really need are just the headers and startup code for my device variant.
