MCIMX8QXP-CPU
MCIMX8QXP-CPU
2,586件の閲覧回数
NereaB
Hello All,
I would like to know which class of PCB is the board of the MCIMX8QXP-CPU kit. I cannot find a table where I can make a direct  link between the minimum line width and the PCB class. I know that higher the class, thinner the lines. I saw that the majority of the lines on the PCB are 0.1mm width with some lines with 0.06mm widht. Can you help me?
Thanks in advance,
Nerea
5 返答(返信)
2,566件の閲覧回数
NereaB
Thanks! Do you know which is the minimum line width used in the design?
Thanks in advance,
Nerea
2,559件の閲覧回数
riteshmpatel
Hi @NereaB,
Kindly refer to the impedance table (Fab layer) in the EVK PCB layout.
As per the Impedance table, the minimum trace width used is 3.5 mils for routing 100R differential signals.
Thanks & Regards,
Ritesh M Patel
2,556件の閲覧回数
NereaB
Thanks @riteshmpatel ,
Is there any other trace which is smaller but it is not on the impedance table?
2,553件の閲覧回数
riteshmpatel
Hi @NereaB,
Due to the design constraints, very few signals are routed with 2.5 mils in the layout and this is the minimum trace width used in the design.
Thanks & Regards,
Ritesh M Patel
2,573件の閲覧回数
riteshmpatel
Hi @NereaB,
I hope you are doing well.
Please accept my apologies for the delay in response.
MCIMX8QXP-CPU MEK kit has been fabricated as per the PCB IPC class IPC-A-600.
Thanks & Regards,
Ritesh M Patel
