MCIMX6Q-SDB problem with MFGtool
已解决
跳至解决方案
2,057 次查看
mikewang
Hi all, I have a problem using MFG tool to program u-boot to eMMC, the steps as below
1. modify cgf.ini ,
[profiles]
chip = MX6Q Linux Update
[platform]
board = SABRE SD
[LIST]
name = Android-SabreSD-eMMC
2. add boot.img,recovery.img,system.img,u-boot.bin to OS Firmware\files\android
3. SW6 set to 11100110b ,  power on
4. start MfgTool2.exe and downloading successful , power off and SW6 set to 11100110b, I can't see any u-boot message from uart after power on
But I modify cfg.ini with name = Sabre-SD(programming to sdcard) and do the process as above with sdcard and SW6 set to 01000010b after download, It has u-boot message output from uart
标签 (3)
1 解答
1,698 次查看
mikewang
This problem has been solved. SW6 set to 01100011b befor power on.
在原帖中查看解决方案
1 回复
1,699 次查看
mikewang
