Long gaps between SPI transmissions
marcingrzelak
in my program I would like to read an external time counter by SPI and I would like to receive a fairly accurate time. But when I starts transmissions one after another,  the difference between successive readings is ~70 us. A few us for SPI transmissions and remaining time is the gap between transmissions. How can I minimize this gap?
I'm using SPI by ioctl.
Thanks for help.
Labels (2)
Hi marcingrzelak
gaps may be caused by delays intoduced by bus arbiters NIC-301 and
I am afraid there is no way to avoid it. If possible one can try to use bursts
configured by ECSPIx_CONREG register.
