Lock TCM using RDC on iMX7d
3,161件の閲覧回数
chandiniindavar
i am trying to lock down TCM using RDC for M4 so that A7 cant access memory , is it possible ?
As i am running M4 it opens access for A7 but i dont want that .
Could please anyone tell me is it possible ? and How we can do that ?
NOTE :
I have already checked in FreeRTOS_BSP_i.MX_7Dual_API_Reference_Manual.pdf , i cant find any info
Thank you
Chandini
ラベル(4)
3 返答(返信)
3,034件の閲覧回数
Hi Chandini
aavailable memories with domain access permissions are described in
sect.3.2.4.3 Memory Region Map i.MX7D Reference Manual
and one can add necessary changes to code.
http://cache.nxp.com/files/32bit/doc/ref_manual/IMX7DRM.pdf
3,034件の閲覧回数
chandiniindavar
Hi igor
I cant see TCM in that memory table , that means we cant lock down using RDC ?
Thank you
Chandini
3,034件の閲覧回数
for TCM one can check presentation slide 46
i.MX 7D with FreeRTOS
