Load application from QSPI to RAM - imx7ulp
1,736 次查看
klaas
Hi all,
I'm trying to write a costum bootloader for the CM4 on a imx7ulp using IAR EWARM.
My goal is to manually copy the application from QSPI and then execute it.
To me this seems to be a common use-case but I can't find any examples helping me. Mainly I'm not sure which parts of the image residing in the QSPI I need to copy in which locations of the RAM.
Any help or links to examples are welcome!
Klaas
标记 (2)
1,727 次查看
klaas
Any ideas?
Thanks!
