Linux-fslc temperature calibration in kernel driver imx_thermal.c
ennebi
I'm using Linux-fslc with imx6ull.
I observed that the "i.MX 6ULL Applications Processor Reference Manual", at "Chapter 52 Temperature Monitor" specifies that temperature calibration is defined with 2 points:
- (N1, T1) = (ROOM_COUNT, 25.0)
- (N2, T2) = (HOT_COUNT, HOT_TEMP)
While the kernel driver imx_thermal.c (5.15 and 6.12 are the same), in imx_init_calib() considers only one calibration point: the OCOTP_ANA1[ROOM_COUNT] at 25°C as in the following code extract:
static int imx_init_calib(struct platform_device *pdev, u32 ocotp_ana1)
	struct imx_thermal_data *data = platform_get_drvdata(pdev);
	int n1;
	u64 temp64;
	if (ocotp_ana1 == 0 || ocotp_ana1 == ~0) {
		dev_err(&pdev->dev, "invalid sensor calibration data\n");
		return -EINVAL;
	 * On i.MX7D, we only use the calibration data at 25C to get the temp,
	 * Tmeas = ( Nmeas - n1) + 25; n1 is the fuse value for 25C.
	if (data->socdata->version == TEMPMON_IMX7D) {
		data->c1 = (ocotp_ana1 >> 9) & 0x1ff;
		return 0;
	 * The sensor is calibrated at 25 °C (aka T1) and the value measured
	 * (aka N1) at this temperature is provided in bits [31:20] in the
	 * i.MX's OCOTP value ANA1.
	 * To find the actual temperature T, the following formula has to be used
	 * when reading value n from the sensor:
	 * T = T1 + (N - N1) / (0.4148468 - 0.0015423 * N1) °C + 3.580661 °C
	 *   = [T1' - N1 / (0.4148468 - 0.0015423 * N1) °C] + N / (0.4148468 - 0.0015423 * N1) °C
	 *   = [T1' + N1 / (0.0015423 * N1 - 0.4148468) °C] - N / (0.0015423 * N1 - 0.4148468) °C
	 *   = c2 - c1 * N
	 * with
	 *  T1' = 28.580661 °C
	 *   c1 = 1 / (0.0015423 * N1 - 0.4297157) °C
	 *   c2 = T1' + N1 / (0.0015423 * N1 - 0.4148468) °C
	 *      = T1' + N1 * c1
	n1 = ocotp_ana1 >> 20;
	temp64 = 10000000; /* use 10^7 as fixed point constant for values in formula */
	temp64 *= 1000; /* to get result in °mC */
	do_div(temp64, 15423 * n1 - 4148468);
	data->c1 = temp64;
	data->c2 = n1 * data->c1 + 28581;
	return 0;
This line 'n1 = ocotp_ana1 >> 20', drops OCOTP_ANA1[HOT_COUNT] and OCOTP_ANA1[HOT_TEMP] and this leads to temperature inconsistencies.
To confirm this, I did some verifications on a board, by reading registers and calculating trip temperatures:
  • Calibration register OCOTP_ANA1=0x50F4A269
    • ROOM_COUNT=0x50F = 1295
    • HOT_COUNT=0x4A2 = 1186
    • HOT_TEMP(°C)=0x69=105
  • TEMPMON_TEMPSENSE0=0x4A551206
    • ALARM_VALUE=0x4A5=1189
  • TEMPMON_TEMPSENSE2= 0x049D0FFF
    • PANIC_ALARM_VALUE=49D=1181
than I converted [ALARM_VALUE] and  [PANIC_ALARM_VALUE] to celsius temperature according to reference manual indication:
  • Tmeas = HOT_TEMP - (Nmeas - HOT_COUNT) * ((HOT_TEMP - 25.0) /
    (ROOM_COUNT – HOT_COUNT))
so I got:
  • Alarm/Passive temperature = 102,8°C
  • Panic temperature = 108.7°C
those temperatures are greater than default trip temperature:
  • Alarm/passive temperature = 95°C (10°c less than max temperature of 105°C)
  • Panic temperature = 100°C (5°C less than max temperature of 105°C)
This looks like a potentially critical issue in the driver where the panic temperature is already above the maximum operating temperature from datasheet.
Can you confirm the issue?
JorgeCas
Have you encountered any temperature measurement inaccuracies or trip temperature points are incorrect?
I have discussed the code with owner. It's an very old code and he though the algorithm should be okay.
Best regards.
ennebi
Hi Jorge,
as I reported in my initial post, I confirm you that trip temperature points are incorrect:
  • actual Alarm/Passive temperature is 102,8°C instead of 95°C
  • actual Panic temperature is 108.7°C instead of 100°C
This is a potentially critical issue, the panic temperature is above the maximum operating temperature of 105°C.
JorgeCas
The coefficients used for single-point calibration and two-point calibration differ significantly. Regarding your question—have you compared the temperature derived from single-point calibration against actual ambient conditions to assess error margins?
On iMX6, single-point calibration is applied with calculations referenced in imx_init_calib, incorporating additional coefficients c1 and c2. Notably, even imx_set_alarm_temp utilizes single-point calibration coefficients when configuring alarm thresholds.
Crucially, attempting to inversely convert single-point calibration results using two-point calibration methodology is fundamentally incorrect—the calibration frameworks are not interchangeable or reversible in this manner.
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2189166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELinux-fslc%20temperature%20calibration%20in%20kernel%20driver%20imx_thermal.c%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI'm%20using%20Linux-fslc%20with%20imx6ull.%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20observed%20that%20the%20%22i.MX%206ULL%20Applications%20Processor%20Reference%20Manual%22%2C%20at%20%22Chapter%2052%20Temperature%20Monitor%22%20specifies%20that%20temperature%20calibration%20is%20defined%20with%202%20points%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E-%26nbsp%3B(N1%2C%20T1)%20%3D%20(ROOM_COUNT%2C%2025.0)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E-%26nbsp%3B(N2%2C%20T2)%20%3D%20(HOT_COUNT%2C%20HOT_TEMP)%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EWhile%20the%20kernel%20driver%20imx_thermal.c%20(5.15%20and%206.12%20are%20the%20same)%2C%20in%26nbsp%3B%3CSPAN%3Eimx_init_calib()%20considers%20only%20one%20calibration%20point%3A%20the%26nbsp%3BOCOTP_ANA1%5BROOM_COUNT%5D%20at%2025%C2%B0C%20as%20in%20the%20following%20code%20extract%3A%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3Estatic%20int%20imx_init_calib(struct%20platform_device%20*pdev%2C%20u32%20ocotp_ana1)%0A%7B%0A%09struct%20imx_thermal_data%20*data%20%3D%20platform_get_drvdata(pdev)%3B%0A%09int%20n1%3B%0A%09u64%20temp64%3B%0A%0A%09if%20(ocotp_ana1%20%3D%3D%200%20%7C%7C%20ocotp_ana1%20%3D%3D%20~0)%20%7B%0A%09%09dev_err(%26amp%3Bpdev-%26gt%3Bdev%2C%20%22invalid%20sensor%20calibration%20data%5Cn%22)%3B%0A%09%09return%20-EINVAL%3B%0A%09%7D%0A%0A%09%2F*%0A%09%20*%20On%20i.MX7D%2C%20we%20only%20use%20the%20calibration%20data%20at%2025C%20to%20get%20the%20temp%2C%0A%09%20*%20Tmeas%20%3D%20(%20Nmeas%20-%20n1)%20%2B%2025%3B%20n1%20is%20the%20fuse%20value%20for%2025C.%0A%09%20*%2F%0A%09if%20(data-%26gt%3Bsocdata-%26gt%3Bversion%20%3D%3D%20TEMPMON_IMX7D)%20%7B%0A%09%09data-%26gt%3Bc1%20%3D%20(ocotp_ana1%20%26gt%3B%26gt%3B%209)%20%26amp%3B%200x1ff%3B%0A%09%09return%200%3B%0A%09%7D%0A%0A%09%2F*%0A%09%20*%20The%20sensor%20is%20calibrated%20at%2025%20%C2%B0C%20(aka%20T1)%20and%20the%20value%20measured%0A%09%20*%20(aka%20N1)%20at%20this%20temperature%20is%20provided%20in%20bits%20%5B31%3A20%5D%20in%20the%0A%09%20*%20i.MX's%20OCOTP%20value%20ANA1.%0A%09%20*%20To%20find%20the%20actual%20temperature%20T%2C%20the%20following%20formula%20has%20to%20be%20used%0A%09%20*%20when%20reading%20value%20n%20from%20the%20sensor%3A%0A%09%20*%0A%09%20*%20T%20%3D%20T1%20%2B%20(N%20-%20N1)%20%2F%20(0.4148468%20-%200.0015423%20*%20N1)%20%C2%B0C%20%2B%203.580661%20%C2%B0C%0A%09%20*%20%20%20%3D%20%5BT1'%20-%20N1%20%2F%20(0.4148468%20-%200.0015423%20*%20N1)%20%C2%B0C%5D%20%2B%20N%20%2F%20(0.4148468%20-%200.0015423%20*%20N1)%20%C2%B0C%0A%09%20*%20%20%20%3D%20%5BT1'%20%2B%20N1%20%2F%20(0.0015423%20*%20N1%20-%200.4148468)%20%C2%B0C%5D%20-%20N%20%2F%20(0.0015423%20*%20N1%20-%200.4148468)%20%C2%B0C%0A%09%20*%20%20%20%3D%20c2%20-%20c1%20*%20N%0A%09%20*%0A%09%20*%20with%0A%09%20*%0A%09%20*%20%20T1'%20%3D%2028.580661%20%C2%B0C%0A%09%20*%20%20%20c1%20%3D%201%20%2F%20(0.0015423%20*%20N1%20-%200.4297157)%20%C2%B0C%0A%09%20*%20%20%20c2%20%3D%20T1'%20%2B%20N1%20%2F%20(0.0015423%20*%20N1%20-%200.4148468)%20%C2%B0C%0A%09%20*%20%20%20%20%20%20%3D%20T1'%20%2B%20N1%20*%20c1%0A%09%20*%2F%0A%09n1%20%3D%20ocotp_ana1%20%26gt%3B%26gt%3B%2020%3B%0A%0A%09temp64%20%3D%2010000000%3B%20%2F*%20use%2010%5E7%20as%20fixed%20point%20constant%20for%20values%20in%20formula%20*%2F%0A%09temp64%20*%3D%201000%3B%20%2F*%20to%20get%20result%20in%20%C2%B0mC%20*%2F%0A%09do_div(temp64%2C%2015423%20*%20n1%20-%204148468)%3B%0A%09data-%26gt%3Bc1%20%3D%20temp64%3B%0A%09data-%26gt%3Bc2%20%3D%20n1%20*%20data-%26gt%3Bc1%20%2B%2028581%3B%0A%0A%09return%200%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EThis%20line%20'%3C%2FSPAN%3E%3CSPAN%3En1%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%20ocotp_ana1%20%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E20'%2C%26nbsp%3Bdrops%26nbsp%3BOCOTP_ANA1%5BHOT_COUNT%5D%20and%26nbsp%3BOCOTP_ANA1%5BHOT_TEMP%5D%20and%20this%20leads%20to%20temperature%26nbsp%3Binconsistencies.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ETo%20confirm%20this%2C%20I%20did%20some%20verifications%20on%20a%20board%2C%20by%20reading%20registers%20and%20calculating%20trip%20temperatures%3A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3ECalibration%20register%26nbsp%3BOCOTP_ANA1%3D0x50F4A269%3CBR%20%2F%3E%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%3EROOM_COUNT%3D0x50F%20%3D%201295%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EHOT_COUNT%3D0x4A2%20%3D%201186%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EHOT_TEMP(%C2%B0C)%3D0x69%3D105%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3ETEMPMON_TEMPSENSE0%3D0x4A551206%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%3EALARM_VALUE%3D0x4A5%3D1189%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3ETEMPMON_TEMPSENSE2%3D%26nbsp%3B0x049D0FFF%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%3EPANIC_ALARM_VALUE%3D49D%3D1181%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3Ethan%20I%20converted%20%5BALARM_VALUE%5D%20and%26nbsp%3B%20%5BPANIC_ALARM_VALUE%5D%20to%20celsius%20temperature%20according%20to%20reference%20manual%20indication%3A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3ETmeas%20%3D%20HOT_TEMP%20-%20(Nmeas%20-%20HOT_COUNT)%20*%20((HOT_TEMP%20-%2025.0)%20%2F%3CBR%20%2F%3E(ROOM_COUNT%20%E2%80%93%20HOT_COUNT))%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3Eso%20I%20got%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CUL%3E%3CLI%3EAlarm%2FPassive%20temperature%20%3D%20102%2C8%C2%B0C%3C%2FLI%3E%3CLI%3EPanic%20temperature%20%3D%20108.7%C2%B0C%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3Ethose%20temperatures%20are%20greater%20than%20default%20trip%20temperature%3A%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3E%3CSPAN%3EAlarm%2Fpassive%20temperature%20%3D%2095%C2%B0C%20(10%C2%B0c%20less%20than%20max%20temperature%20of%20105%C2%B0C)%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EPanic%20temperature%20%3D%20100%C2%B0C%20(5%C2%B0C%20less%20than%20max%20temperature%20of%20105%C2%B0C)%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3EThis%20looks%20like%20a%20potentially%20critical%20issue%20in%20the%20driver%20where%20the%20panic%20temperature%20is%20already%20above%20the%20maximum%20operating%20temperature%20from%20datasheet.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ECan%20you%20confirm%20the%20issue%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2189166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6%20All%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2207009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Linux-fslc%20temperature%20calibration%20in%20kernel%20driver%20imx_thermal.c%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2207009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EThe%20coefficients%20used%20for%20single-point%20calibration%20and%20two-point%20calibration%20differ%20significantly.%20Regarding%20your%20question%E2%80%94have%20you%20compared%20the%20temperature%20derived%20from%20single-point%20calibration%20against%20actual%20ambient%20conditions%20to%20assess%20error%20margins%3F%3C%2FP%3E%0A%3CP%3EOn%20iMX6%2C%20single-point%20calibration%20is%20applied%20with%20calculations%20referenced%20in%20imx_init_calib%2C%20incorporating%20additional%20coefficients%20c1%20and%20c2.%20Notably%2C%20even%20imx_set_alarm_temp%20utilizes%20single-point%20calibration%20coefficients%20when%20configuring%20alarm%20thresholds.%3C%2FP%3E%0A%3CP%3ECrucially%2C%20attempting%20to%20inversely%20convert%20single-point%20calibration%20results%20using%20two-point%20calibration%20methodology%20is%20fundamentally%20incorrect%E2%80%94the%20calibration%20frameworks%20are%20not%20interchangeable%20or%20reversible%20in%20this%20manner.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Linux-fslc%20temperature%20calibration%20in%20kernel%20driver%20imx_thermal.c%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Jorge%2C%3C%2FP%3E%3CP%3Eas%20I%20reported%20in%20my%20initial%20post%2C%20I%20confirm%20you%20that%26nbsp%3B%3CSPAN%3Etrip%20temperature%20points%20are%20incorrect%3A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3Eactual%20Alarm%2FPassive%20temperature%20is%20102%2C8%C2%B0C%20instead%20of%2095%C2%B0C%3C%2FLI%3E%3CLI%3Eactual%20Panic%20temperature%20is%20108.7%C2%B0C%20instead%20of%20100%C2%B0C%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3EThis%20is%20a%20potentially%20critical%20issue%2C%20the%20panic%20temperature%20is%20above%20the%20maximum%20operating%20temperature%20of%20105%C2%B0C.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Linux-fslc%20temperature%20calibration%20in%20kernel%20driver%20imx_thermal.c%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EHave%20you%20encountered%20any%20temperature%20measurement%20inaccuracies%20or%20trip%20temperature%20points%20are%20incorrect%3F%3C%2FP%3E%0A%3CP%3EI%20have%20discussed%20the%20code%20with%20owner.%20It's%20an%20very%20old%20code%20and%20he%20though%20the%20algorithm%20should%20be%20okay.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E
