Linux for IMX8 : switch to virtual console
tan-k
I need to switch to virtual console.
I try, but have an issue. Cannot switch to virtual console sometimes.
Could you please tell me this solution?
About details, please refer below.
[Environment]
Evaluation Kit : 8MMINILPD4-EVK (Connect HDMI cable, USB keyboard and USB mouse.)
Linux for i.MX : Linux 5.4.70_2.3.0​ (Download "L5.4.70-2.3.0_images_MX8MMEVK.zip" and flash "imx-image-full-imx8mmevk.wic" to SD card.)
[Procedure]
1.Trun on the power to evaluation kit. Then boot from SD card.
  ->Wayland Weston desktop is shown on the screen.
2.Press "Ctrl + Alt + Fn1(or Fn2-Fn6)" key to switch to virtual console.
  ->Virtual console screen is shown for a second, then Wayland Weston desktop is shown.
    Move the mouse, but the pointer on the screen does not move.
3. Press "Ctrl + Alt + Fn7" key to return Wayland Weston desktop.
  ->Move the mouse, the pointer on the screen moves normally.
4.Click weston-terminal icon on toolbar and execute weston-terminal. Input some keys on terminal.
  Then press "Ctrl + Alt + Fn1(or Fn2-Fn6)" key to switch to virtual console.
  ->Can switch to virtual console normally.
5. Press "Ctrl + Alt + Fn7" key to return Wayland Weston desktop.
  ->Wayland Weston desktop is shown.
6.Press "Ctrl + Alt + Fn1(or Fn2-Fn6)" key to switch to virtual console again.
  ->Same result as procedure 2. Then input some keys.
7. Press "Ctrl + Alt + Fn7" key to return Wayland Weston desktop.
8.Click weston-terminal icon on toolbar and execute weston-terminal. Input some keys on terminal.
    And keys which I input at procedure 6 are shown virtual console screen.
I think there is issue when switch the screen.
Switching control works normally because we can input key.
Any help would be appreciated.
Thank you.
Zhiming_Liu
The patch has been attached.
josephzhou1
Contributor V
good
Joseph Zhou Jianhui / Senior Embedded Software Engineer, Singapore
JoeChen
We have met the similar problem, but our Linux kernel is 4.14.98; could you also provide a patch solution to us?
Thank you very much!
BR,
Joe Chen.
Zhiming_Liu
tan-k
This problem was solved after applied your patch.
Thanks to your support!
Zhiming_Liu
I have confimed this issue.It seems weston bug.You can see the mouse can not move because the visual console is opened,but the weston don't show.I am trying to find out the problem.
Zhiming
tan-k
Thank you for your reply !
I look forward to additional information !
Zhiming_Liu
Hi tan-k
This bug is report to expert team and waiting for their reply.
tan-k
Thank you for telling me current situation.
We hope expert team solve this bug.
Zhiming_Liu
This bug has been posted to software team waiting to be fixed
Zhiming
tan-k
Thank you!
We hope software team fix this bug quickly.
