Linux Test Project(ltp-imx) - i.MX6Q
3,041 次查看
dilip
I am trying to compile ltp-imx to test the linux port on my custom platform based on i.MX6Q. The package and whole set of patches are missing from  from ltib installation. Found after a bit of research that for i.MX51, ltib and core patches for ltp comes as a separate package, TestCode_Release_SDK_MX51_200912.zip
Where can I find similar release for i.MX6Q?
Dilip
标记 (2)
3 回复数
2,542 次查看
YixingKong
Senior Contributor IV
Dilip
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow to resolved the issue, can we close the discussion? If you still need help, please feel free to reply with an update to this discussion.
Yixing
2,542 次查看
dilip
No. Issue is still there.
BTW, raised and SR and got peply that LTP is not supported from i.MX6 onwards. It is strange that the LTIB release for i.MX6Q comes with LTP package and doesn't work
thanks,
Dilip
2,542 次查看
YixingKong
Dilip
To raise a SR is same as to post here. We are moving all support from SR system to community now. As to message you got about LTP is not supported, that should be true. And so I will close here. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
