LVDS on IMX8MP
LVDS on IMX8MP
1,565 次查看
SanthoshRajavel
I am new to Yocto and the i.MX8M Plus platform. I need to enable the LVDS port in my Yocto build, but I couldn’t find a clear reference on how to do this. Could you please suggest where I should start and share any relevant links or documentation for enabling LVDS?
I am using the i.MX8M Plus LPDDR4 EVK and Yocto Scarthgap.
4 回复数
1,483 次查看
SanthoshRajavel
This is my error after change my dtb file
root@imx8mp-lpddr4-evk:~# dmesg | grep -E "ldb|panel|lcdif3"
[ 0.090951] platform panel-lvds: Fixed dependency cycle(s) with /ldb-display- controller/lvds-channel@0
[ 1.605694] panel-lvds panel-lvds: /panel-lvds: problems parsing panel-timing (-22)
[ 1.613391] panel-lvds: probe of panel-lvds failed with error -22
[ 1.630510] imx8mp-ldb ldb-display-controller: Failed to create device link ( 0x180) with 32e90000.lcd-controller
[ 2.659304] imx8mp-ldb ldb-display-controller: Failed to create device link ( 0x180) with phy-lvds
1,484 次查看
SanthoshRajavel
Now i create a custom dts for to enable lvds channel 0 only but i didn't get any positive response . I attach my code can you help me to find the problem. Also attach my display config details.Media (2).jpg
My code
// SPDX-License-Identifier: GPL-2.0+
* Custom LVDS panel: 800x480 @ 60Hz
* Timing source: User-provided Datasheet Table
#include "imx8mp-evk.dts"
model = "NXP i.MX8M Plus EVK - 800x480 LVDS";
compatible = "fsl,imx8mp-evk", "fsl,imx8mp";
panel_lvds: panel-lvds {
compatible = "panel-lvds";
status = "okay";
data-mapping = "jeida-24";
panel-timing {
/* DCLK frequency: 25.005 MHz (from Typ. value) */
clock-frequency = <25005000>;
hactive = <800>; /* thd */
vactive = <480>; /* tvd */
/* Horizontal (th): Typ total 858, using values in Min-Max range */
hfront-porch = <28>; /* Adjusted for th total stability */
hsync-len = <10>; /* thpw (Range 6-14) */
hback-porch = <20>; /* thbp (Range 14-34) */
/* Vertical (tv): Typ total 488, using values in Min-Max range */
vfront-porch = <5>; /* ttvfp (Range 5-41) */
vsync-len = <2>; /* tvpw (Range 1-2) */
vback-porch = <1>; /* tvbp (Range 3-4, adjusted for tv total) */
/* Mandatory polarity flags for kernel 6.6 parser */
hsync-active = <0>;
vsync-active = <0>;
de-active = <1>;
pixelclk-active = <0>;
port {
panel_lvds_in: endpoint {
remote-endpoint = <&ldb_out>;
/* Remove base bridge to avoid resource conflicts */
/delete-node/ &lvds_bridge;
&ldb_phy {
status = "okay";
&ldb {
status = "okay";
/* Assign clocks to fix 'Failed to create device link' */
assigned-clocks = <&clk IMX8MP_VIDEO_PLL1_OUT>,
<&clk IMX8MP_CLK_MEDIA_LDB>,
<&clk IMX8MP_CLK_MEDIA_DISP2_PIX>;
assigned-clock-parents = <&clk IMX8MP_VIDEO_PLL1_BYPASS>,
<&clk IMX8MP_VIDEO_PLL1_OUT>;
lvds-channel@0 {
fsl,data-mapping = "jeida-24";
fsl,data-width = <24>;
status = "okay";
/* Clean and re-map the port to the panel */
/delete-node/ port@1;
port@1 {
reg = <1>;
ldb_out: endpoint {
remote-endpoint = <&panel_lvds_in>;
/* LCDIF3 is mandatory for LVDS on i.MX8MP */
&lcdif3 {
status = "okay";
&hdmi {
status = "disabled";
1,516 次查看
SanthoshRajavel
I have downloaded the BSP and created a custom Qt application, which is currently running successfully on HDMI. Now, I want to display the output through LVDS, but I am unable to find proper information on how to enable and configure the LVDS display in the BSP and Yocto build.
1,535 次查看
Bio_TICFSL
Download the BSP from NXP:
https://www.nxp.com/design/design-center/software/embedded-software/i-mx-software/embedded-linux-for...
And follow the latest documentation version, in particula the Yocto user guide.
regards
%3CLINGO-SUB%20id%3D%22lingo-sub-2301355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20%E4%B8%8A%E7%9A%84%20LVDS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2301355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%98%AF%20Yocto%20%E5%92%8C%20i.MX8M%20Plus%20%E5%B9%B3%E5%8F%B0%E7%9A%84%E6%96%B0%E6%89%8B%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%E6%88%91%E7%9A%84%20Yocto%20%E7%89%88%E6%9C%AC%E4%B8%AD%E5%90%AF%E7%94%A8%20LVDS%20%E7%AB%AF%E5%8F%A3%EF%BC%8C%E4%BD%86%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E5%85%B3%E4%BA%8E%E5%A6%82%E4%BD%95%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%E7%9A%84%E6%98%8E%E7%A1%AE%E5%8F%82%E8%80%83%E8%B5%84%E6%96%99%E3%80%82%E8%83%BD%E5%90%A6%E5%BB%BA%E8%AE%AE%E6%88%91%E4%BB%8E%E5%93%AA%E9%87%8C%E5%85%A5%E6%89%8B%EF%BC%8C%E5%B9%B6%E5%88%86%E4%BA%AB%E5%90%AF%E7%94%A8%20LVDS%20%E7%9A%84%E7%9B%B8%E5%85%B3%E9%93%BE%E6%8E%A5%E6%88%96%E6%96%87%E6%A1%A3%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20i.MX8M%20Plus%20LPDDR4%20EVK%20%E5%92%8C%20Yocto%3CSTRONG%3EScarthgap%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2301355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%9B%BE%E5%BD%A2%E4%B8%8E%E6%98%BE%E7%A4%BA%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2301814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LVDS%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2301814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E4%B8%8B%E8%BD%BD%E4%BA%86%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E5%B9%B6%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E8%87%AA%E5%AE%9A%E4%B9%89%20Qt%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E8%AF%A5%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%20HDMI%20%E4%B8%8A%E6%88%90%E5%8A%9F%E8%BF%90%E8%A1%8C%E3%80%82%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E6%83%B3%E9%80%9A%E8%BF%87%20LVDS%20%E6%98%BE%E7%A4%BA%E8%BE%93%E5%87%BA%EF%BC%8C%E4%BD%86%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%20%E5%92%8C%20Yocto%20%E7%89%88%E6%9C%AC%E4%B8%AD%E6%89%BE%E5%88%B0%E6%9C%89%E5%85%B3%E5%A6%82%E4%BD%95%E5%90%AF%E7%94%A8%E5%92%8C%E9%85%8D%E7%BD%AE%20LVDS%20%E6%98%BE%E7%A4%BA%E5%99%A8%E7%9A%84%E6%AD%A3%E7%A1%AE%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2301514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LVDS%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2301514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E4%BB%8E%E6%81%A9%E6%99%BA%E6%B5%A6%E4%B8%8B%E8%BD%BD%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fembedded-software%2Fi-mx-software%2Fembedded-linux-for-i-mx-applications-processors%3AIMXLINUX%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fembedded-software%2Fi-mx-software%2Fembedded-linux-for-i-mx-applications-processors%3AIMXLINUX%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%B9%B6%E5%85%B3%E6%B3%A8%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%20Yocto%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LVDS%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E6%9B%B4%E6%94%B9%E6%88%91%E7%9A%84%20dtb%20%E6%96%87%E4%BB%B6%3CBR%20%2F%3E%E6%A0%B9%E7%9B%AE%E5%BD%95%E5%90%8E%E7%9A%84%E9%94%99%E8%AF%AF%20%40imx8mp-lpdr4-evk%EF%BC%9A~%23%20dmesg%20%7C%20grep-E%20%22%20ldb%7Cpanel%7Clcdif3%20%22%20%3CBR%20%2F%3E%20%5B0.090951%5D%20%E5%B9%B3%E5%8F%B0%E9%9D%A2%E6%9D%BF%20lvds%EF%BC%9A%E4%BD%BF%E7%94%A8%20%2Fldb-display-controller%2Flvds%20%E9%A2%91%E9%81%93%E4%BF%AE%E5%A4%8D%E4%BE%9D%E8%B5%96%E5%91%A8%E6%9C%9F%20%400%20%5B1.605694%5D%20panel-lvds%20%E9%9D%A2%E6%9D%BF%E7%AD%89%E7%BA%A7%EF%BC%9A%2Fpanel-lvds%EF%BC%9A%E9%97%AE%E9%A2%98%E8%A7%A3%E6%9E%90%E9%9D%A2%E6%9D%BF%E8%AE%A1%E6%97%B6%20(-22)%20%5B1.613391%5D%20panel-lvds%EF%BC%9Apanel-lvds%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%20-22%20%3CBR%20%2F%3E%20%5B1.630510%5D%20imx8mp-ldb%20ldb%20ldb-display-controller%EF%BC%9A%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%2032e90000.lcd-controller%20%E5%88%9B%E5%BB%BA%E8%AE%BE%E5%A4%87%E9%93%BE%E6%8E%A5%20(0x180)%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%5B2.659304%5D%20imx8mp-ldb%20ldb%20ldb-display-controller%EF%BC%9A%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20phy-lvds%20%E5%88%9B%E5%BB%BA%E8%AE%BE%E5%A4%87%E9%93%BE%E6%8E%A5%20(0x180)%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LVDS%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E8%87%AA%E5%AE%9A%E4%B9%89%20dts%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%8F%AA%E5%90%AF%E7%94%A8%20lvds%20%E9%A2%91%E9%81%93%200%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E5%BE%97%E5%88%B0%E4%BB%BB%E4%BD%95%E7%A7%AF%E6%9E%81%E5%9B%9E%E5%BA%94%E3%80%82%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%A0%E8%83%BD%E5%B8%AE%E6%88%91%E6%89%BE%E5%88%B0%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E5%90%97%EF%BC%9F%E5%90%8C%E6%97%B6%E9%99%84%E4%B8%8A%E6%88%91%E7%9A%84%E6%98%BE%E7%A4%BA%E9%85%8D%E7%BD%AE%E8%AF%A6%E6%83%85%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Media%20(2).jpg%22%20style%3D%22width%3A%20862px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Media%20(2).jpg%22%20style%3D%22width%3A%20862px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374811i35165387584C8FE8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Media%20(2).jpg%22%20alt%3D%22Media%20(2).jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%20%3C%2FP%3E%3CP%3E%2F%2F%20SPDX-License-Identifier%EF%BC%9AGPL-2.0%2B%3CBR%20%2F%3E%2F*%3CBR%20%2F%3E*%20%E5%AE%9A%E5%88%B6%20LVDS%20%E9%9D%A2%E6%9D%BF%EF%BC%9A800x480%20%40%2060Hz%3CBR%20%2F%3E*%20%E5%AE%9A%E6%97%B6%E6%BA%90%EF%BC%9A%E7%94%A8%E6%88%B7%E6%8F%90%E4%BE%9B%E7%9A%84%E6%95%B0%E6%8D%AE%E8%A1%A8%3CBR%20%2F%3E*%2F%3C%2FP%3E%3CP%3E%23include%22imx8mp-evk.dts%22%3C%2FP%3E%3CP%3E%2F%20%7B%3CBR%20%2F%3Emodel%20%3D%22NXP%20i.MX8M%20Plus%20EVK%20-%20800x480%20LVDS%22%3B%3CBR%20%2F%3Ecompatible%20%3D%22fsl%2Cimx8mp-evk%22%2C%22fsl%2Cimx8mp%22%20%EF%BC%9B%3C%2FP%3E%3CP%3Epanel_lvds%3A%20panel-lvds%20%7B%3CBR%20%2F%3Ecompatible%20%3D%22panel-lvds%22%3B%3CBR%20%2F%3Estatus%20%3D%22okay%22%3B%3CBR%20%2F%3Edata-mapping%20%3D%22jeida-24%22%20%EF%BC%9B%3C%2FP%3E%3CP%3Epanel-timing%20%7B%3CBR%20%2F%3E%2F*%20DCLK%20%E9%A2%91%E7%8E%87%EF%BC%9A25.005%20MHz%EF%BC%88%E6%9D%A5%E8%87%AA%E5%85%B8%E5%9E%8B%E5%80%BC%EF%BC%89%E3%80%82%E5%80%BC%EF%BC%89%20*%2F%3CBR%20%2F%3Eclock-frequency%20%3D%26lt%3B25005000%26gt%3B%3B%3CBR%20%2F%3Ehactive%20%3D%26lt%3B800%26gt%3B%3B%20%2F*%20thd%20*%2F%3CBR%20%2F%3Evactive%20%3D%26lt%3B480%26gt%3B%3B%20%2F*%20tvd%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Horizontal%20(th)%EF%BC%9A%E5%85%B8%E5%9E%8B%E5%80%BC%E6%80%BB%E8%AE%A1%20858%EF%BC%8C%E4%BD%BF%E7%94%A8%20Min-Max%20%E8%8C%83%E5%9B%B4%E5%86%85%E7%9A%84%E5%80%BC%20*%2F%3CBR%20%2F%3Ehfront-porch%20%3D%26lt%3B28%26gt%3B%3B%20%2F*%20%E6%A0%B9%E6%8D%AE%20th%20%E6%80%BB%E7%A8%B3%E5%AE%9A%E6%80%A7%E8%BF%9B%E8%A1%8C%E8%B0%83%E6%95%B4%20*%2F%3CBR%20%2F%3Ehsync-len%20%3D%26lt%3B10%26gt%3B%3B%20%2F*%20thpw%20(Range%206-14)%20*%2F%3CBR%20%2F%3Ehback-porch%20%3D%26lt%3B20%26gt%3B%3B%20%2F*%20thbp%20(Range%2014-34)%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Vertical%20(tv)%EF%BC%9ATyp%20%E5%90%88%E8%AE%A1%20488%EF%BC%8C%E4%BD%BF%E7%94%A8%20Min-Max%20%E8%8C%83%E5%9B%B4%E5%86%85%E7%9A%84%E5%80%BC%20*%2F%3CBR%20%2F%3Evfront-porch%20%3D%26lt%3B5%26gt%3B%3B%20%2F*%20ttvfp%EF%BC%88%E8%8C%83%E5%9B%B4%205-41%EF%BC%89%20*%2F%3CBR%20%2F%3Evsync-len%20%3D%26lt%3B2%26gt%3B%3B%20%2F*%20tvpw%EF%BC%88%E8%8C%83%E5%9B%B4%201-2%EF%BC%89%20*%2F%3CBR%20%2F%3Evback-porch%20%3D%26lt%3B1%26gt%3B%3B%20%2F*%20tvbp%EF%BC%88%E8%8C%83%E5%9B%B4%203-4%EF%BC%8C%E6%A0%B9%E6%8D%AE%20tv%20%E5%90%88%E8%AE%A1%E8%B0%83%E6%95%B4%EF%BC%89%20*%2F%3C%2FP%3E%3CP%3E%2F*%20%E5%86%85%E6%A0%B8%206.6%20%E8%A7%A3%E6%9E%90%E5%99%A8%E7%9A%84%E5%BC%BA%E5%88%B6%E6%80%A7%E6%9E%81%E6%80%A7%E6%A0%87%E5%BF%97%20*%2F%3CBR%20%2F%3Ehsync-active%20%3D%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3Evsync-active%20%3D%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3Ede-active%20%3D%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3Epixelclk-active%20%3D%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%7D%EF%BC%9B%3C%2FP%3E%3CP%3E%E7%AB%AF%E5%8F%A3%20%7B%3CBR%20%2F%3Epanel_lvds_in%EF%BC%9A%E7%AB%AF%E7%82%B9%20%7B%3CBR%20%2F%3Eremote-endpoint%20%3D%26lt%3B%26amp%3B%20ldb_out%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%EF%BC%9B%3C%2FP%3E%3CP%3E%2F*%20%E5%88%A0%E9%99%A4%E5%9F%BA%E7%A1%80%E6%A1%A5%E6%8E%A5%E5%99%A8%E4%BB%A5%E9%81%BF%E5%85%8D%E8%B5%84%E6%BA%90%E5%86%B2%E7%AA%81%20*%2F%3CBR%20%2F%3E%2Fdelete-node%2F%26amp%3Blvds_bridge%EF%BC%9B%3C%2FP%3E%3CP%3E%26amp%3Bldb_phy%20%7B%3CBR%20%2F%3Estatus%20%3D%22okay%22%3B%3CBR%20%2F%3E%7D%EF%BC%9B%3C%2FP%3E%3CP%3E%26amp%3B%20ldb%20%7Bst%20%3CBR%20%2F%3E%20atus%20%3D%20%22%20%E5%A5%BD%E5%90%A7%20%22%3B%20%3CBR%20%2F%3E%20%2F*%20%E5%88%86%E9%85%8D%E6%97%B6%E9%92%9F%E6%9D%A5%E4%BF%AE%E5%A4%8D%20%E2%80%9C%E6%97%A0%E6%B3%95%E5%88%9B%E5%BB%BA%E8%AE%BE%E5%A4%87%E9%93%BE%E6%8E%A5%E2%80%9D%20*%2F%20%3CBR%20%2F%3E%20%E5%88%86%E9%85%8D%E7%9A%84%E6%97%B6%E9%92%9F%20%3D%20%26lt%3B%20%26amp%3B%20clk%20imx8MP_VIDEO_PLL1_OUT%20%26gt%3B%2C%20%26lt%3B%20%26amp%3B%20clk%20IMX8MP_CLK_MEDIA_LDB%20%26gt%3B%2C%20%26lt%3B%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%26amp%3B%20clk%20imx8MP_CLK_CLK_MEDIA_DISP2_PIX%20%26gt%3B%EF%BC%9B%3CBR%20%2F%3E%E5%88%86%E9%85%8D%E7%9A%84%E6%97%B6%E9%92%9F%E7%88%B6%E6%AF%8D%20%3D%20%26lt%3B%20%26amp%3B%20clk%20imx8MP_VIDEO_PLL1_BYPASS%20%26gt%3B%EF%BC%8C%26lt%3B%20%26amp%3B%20clk%20IMX8MP_VIDEO_PLL1_OUT%20%26gt%3B%EF%BC%8C%26lt%3B%20%26amp%3B%20clk%20IMX8MP_VIDEO_PLL1_OUT%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%26gt%3B%3B%3C%2FP%3E%3CP%3Elvds-channel%400%20%7B%3CBR%20%2F%3Efsl%2Cdata-mapping%20%3D%22jeida-24%22%3B%3CBR%20%2F%3Efsl%2Cdata-width%20%3D%26lt%3B24%26gt%3B%3B%3CBR%20%2F%3Estatus%20%3D%22okay%22%20%EF%BC%9B%3C%2FP%3E%3CP%3E%2F*%20%E6%B8%85%E7%90%86%E5%B9%B6%E9%87%8D%E6%96%B0%E6%98%A0%E5%B0%84%E7%AB%AF%E5%8F%A3%E5%88%B0%E9%9D%A2%E6%9D%BF%20*%2F%3CBR%20%2F%3E%2Fdelete-node%2F%20port%401%3B%3CBR%20%2F%3Eport%401%20%7B%3CBR%20%2F%3Ereg%20%3D%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3Eldb_out%3A%20endpoint%20%7B%3CBR%20%2F%3Eremote-endpoint%20%3D%26lt%3B%26amp%3B%20panel_lvds_in%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%EF%BC%9B%3C%2FP%3E%3CP%3E%2F*%20i.MX8MP%20%E4%B8%8A%E7%9A%84%20LVDS%20%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20LCDIF3%20*%2F%3CBR%20%2F%3E%26amp%3B%20lcdif3%20%7B%3CBR%20%2F%3Estatus%20%3D%22okay%22%3B%3CBR%20%2F%3E%7D%EF%BC%9B%3C%2FP%3E%3CP%3E%26amp%3Bhdmi%20%7B%3CBR%20%2F%3Estatus%20%3D%22disabled%22%3B%3CBR%20%2F%3E%7D%EF%BC%9B%3C%2FP%3E%3C%2FLINGO-BODY%3E
