LVDS on IMX8MP
LVDS on IMX8MP
1,505件の閲覧回数
SanthoshRajavel
I am new to Yocto and the i.MX8M Plus platform. I need to enable the LVDS port in my Yocto build, but I couldn’t find a clear reference on how to do this. Could you please suggest where I should start and share any relevant links or documentation for enabling LVDS?
I am using the i.MX8M Plus LPDDR4 EVK and Yocto Scarthgap.
4 返答(返信)
1,423件の閲覧回数
SanthoshRajavel
This is my error after change my dtb file
root@imx8mp-lpddr4-evk:~# dmesg | grep -E "ldb|panel|lcdif3"
[ 0.090951] platform panel-lvds: Fixed dependency cycle(s) with /ldb-display- controller/lvds-channel@0
[ 1.605694] panel-lvds panel-lvds: /panel-lvds: problems parsing panel-timing (-22)
[ 1.613391] panel-lvds: probe of panel-lvds failed with error -22
[ 1.630510] imx8mp-ldb ldb-display-controller: Failed to create device link ( 0x180) with 32e90000.lcd-controller
[ 2.659304] imx8mp-ldb ldb-display-controller: Failed to create device link ( 0x180) with phy-lvds
1,424件の閲覧回数
SanthoshRajavel
Now i create a custom dts for to enable lvds channel 0 only but i didn't get any positive response . I attach my code can you help me to find the problem. Also attach my display config details.Media (2).jpg
My code
// SPDX-License-Identifier: GPL-2.0+
* Custom LVDS panel: 800x480 @ 60Hz
* Timing source: User-provided Datasheet Table
#include "imx8mp-evk.dts"
model = "NXP i.MX8M Plus EVK - 800x480 LVDS";
compatible = "fsl,imx8mp-evk", "fsl,imx8mp";
panel_lvds: panel-lvds {
compatible = "panel-lvds";
status = "okay";
data-mapping = "jeida-24";
panel-timing {
/* DCLK frequency: 25.005 MHz (from Typ. value) */
clock-frequency = <25005000>;
hactive = <800>; /* thd */
vactive = <480>; /* tvd */
/* Horizontal (th): Typ total 858, using values in Min-Max range */
hfront-porch = <28>; /* Adjusted for th total stability */
hsync-len = <10>; /* thpw (Range 6-14) */
hback-porch = <20>; /* thbp (Range 14-34) */
/* Vertical (tv): Typ total 488, using values in Min-Max range */
vfront-porch = <5>; /* ttvfp (Range 5-41) */
vsync-len = <2>; /* tvpw (Range 1-2) */
vback-porch = <1>; /* tvbp (Range 3-4, adjusted for tv total) */
/* Mandatory polarity flags for kernel 6.6 parser */
hsync-active = <0>;
vsync-active = <0>;
de-active = <1>;
pixelclk-active = <0>;
port {
panel_lvds_in: endpoint {
remote-endpoint = <&ldb_out>;
/* Remove base bridge to avoid resource conflicts */
/delete-node/ &lvds_bridge;
&ldb_phy {
status = "okay";
&ldb {
status = "okay";
/* Assign clocks to fix 'Failed to create device link' */
assigned-clocks = <&clk IMX8MP_VIDEO_PLL1_OUT>,
<&clk IMX8MP_CLK_MEDIA_LDB>,
<&clk IMX8MP_CLK_MEDIA_DISP2_PIX>;
assigned-clock-parents = <&clk IMX8MP_VIDEO_PLL1_BYPASS>,
<&clk IMX8MP_VIDEO_PLL1_OUT>;
lvds-channel@0 {
fsl,data-mapping = "jeida-24";
fsl,data-width = <24>;
status = "okay";
/* Clean and re-map the port to the panel */
/delete-node/ port@1;
port@1 {
reg = <1>;
ldb_out: endpoint {
remote-endpoint = <&panel_lvds_in>;
/* LCDIF3 is mandatory for LVDS on i.MX8MP */
&lcdif3 {
status = "okay";
&hdmi {
status = "disabled";
1,456件の閲覧回数
SanthoshRajavel
I have downloaded the BSP and created a custom Qt application, which is currently running successfully on HDMI. Now, I want to display the output through LVDS, but I am unable to find proper information on how to enable and configure the LVDS display in the BSP and Yocto build.
1,475件の閲覧回数
Bio_TICFSL
Download the BSP from NXP:
https://www.nxp.com/design/design-center/software/embedded-software/i-mx-software/embedded-linux-for...
And follow the latest documentation version, in particula the Yocto user guide.
regards
%3CLINGO-SUB%20id%3D%22lingo-sub-2301355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%E3%81%AELVDS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2301355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFYocto%E3%81%A8i.MX8M%20Plus%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%92%E5%88%9D%E3%82%81%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82Yocto%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%20LVDS%20%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E6%96%B9%E6%B3%95%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%98%8E%E7%A2%BA%E3%81%AA%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%A9%E3%81%93%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%8B%E3%81%94%E6%8F%90%E6%A1%88%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81LVDS%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E9%96%A2%E9%80%A3%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%84%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3Ei.MX8M%20Plus%20LPDDR4%20EVK%20%E3%81%A8%20Yocto%20%3CSTRONG%3EScarthgap%20%E3%82%92%3C%2FSTRONG%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2301355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20%E3%83%9F%E3%83%8B%20%7C%20i.MX%208M%20%E3%83%8A%E3%83%8E%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2301814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LVDS%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2301814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBSP%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20Qt%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81HDMI%20%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81LVDS%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E5%87%BA%E5%8A%9B%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81BSP%20%E3%81%8A%E3%82%88%E3%81%B3%20Yocto%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%20LVDS%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E9%81%A9%E5%88%87%E3%81%AA%E6%83%85%E5%A0%B1%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2301514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LVDS%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2301514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3ENXP%20%E3%81%8B%E3%82%89%20BSP%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fembedded-software%2Fi-mx-software%2Fembedded-linux-for-i-mx-applications-processors%3AIMXLINUX%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fembedded-software%2Fi-mx-software%2Fembedded-linux-for-i-mx-applications-processors%3AIMXLINUX%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E6%9C%80%E6%96%B0%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%80%81%E7%89%B9%E3%81%AB%20Yocto%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LVDS%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AFdtb%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%99%3CBR%20%2F%3Eroot%40imx8mp-lpddr4-evk%3A~%23%20dmesg%20%7C%20grep%20-E%20%22ldb%7Cpanel%7Clcdif3%22%3CBR%20%2F%3E%20%5B%200.090951%5D%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20panel-lvds%3A%20%2Fldb-display-%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%2Flvds-channel%400%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AE%E5%BE%AA%E7%92%B0%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%201.605694%5D%20panel-lvds%20panel-lvds%3A%20%2Fpanel-lvds%3A%20panel-timing%20%E3%81%AE%E8%A7%A3%E6%9E%90%E4%B8%AD%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(-22)%3CBR%20%2F%3E%20%5B%201.613391%5D%20panel-lvds%3A%20panel-lvds%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-22%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%201.630510%5D%20imx8mp-ldb%20ldb-display-%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3A%2032e90000.lcd-%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20%E3%81%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AA%E3%83%B3%E3%82%AF%20(0x180)%20%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.659304%5D%20imx8mp-ldb%20ldb-display-controller%3A%20phy-lvds%20%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AA%E3%83%B3%E3%82%AF%20(0x180)%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LVDS%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81LVDS%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%200%20%E3%81%AE%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20DTS%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E8%82%AF%E5%AE%9A%E7%9A%84%E3%81%AA%E5%BF%9C%E7%AD%94%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E5%95%8F%E9%A1%8C%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E8%A8%AD%E5%AE%9A%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%82%82%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Media%20(2).jpg%22%20style%3D%22width%3A%20862px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Media%20(2).jpg%22%20style%3D%22width%3A%20862px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374811i35165387584C8FE8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Media%20(2).jpg%22%20alt%3D%22Media%20(2).jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%2F%2F%20SPDX%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E8%AD%98%E5%88%A5%E5%AD%90%3A%20GPL-2.0%2B%3CBR%20%2F%3E%2F*%3CBR%20%2F%3E%20*%20%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0LVDS%E3%83%91%E3%83%8D%E3%83%AB%3A%20800x480%20%40%2060Hz%3CBR%20%2F%3E%20*%20%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%BD%E3%83%BC%E3%82%B9%3A%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%8F%90%E4%BE%9B%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3CBR%20%2F%3E*%2F%3C%2FP%3E%3CP%3E%23include%20%22imx8mp-evk.dts%22%3C%2FP%3E%3CP%3E%2F%20%7B%3CBR%20%2F%3E%E3%83%A2%E3%83%87%E3%83%AB%20%3D%20%22NXP%20i.MX8M%20Plus%20EVK%20-%20800x480%20LVDS%22%3B%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22fsl%2Cimx8mp-evk%22%2C%20%22fsl%2Cimx8mp%22%3B%3C%2FP%3E%3CP%3Epanel_lvds%3A%20%E3%83%91%E3%83%8D%E3%83%ABlvds%20%7B%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22%E3%83%91%E3%83%8D%E3%83%ABLVDS%22%3B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20%3D%20%22jeida-24%22%3B%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%8D%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%20%7B%3CBR%20%2F%3E%20%2F*%20DCLK%20%E5%91%A8%E6%B3%A2%E6%95%B0%3A%2025.005%20MHz%20(Typ.%20%E3%81%8B%E3%82%89)%E4%BE%A1%E5%80%A4%EF%BC%89%20*%2F%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%20%26lt%3B25005000%26gt%3B%3B%3CBR%20%2F%3E%20hactive%20%3D%20%26lt%3B800%26gt%3B%3B%20%2F*%20thd%20*%2F%3CBR%20%2F%3E%20vactive%20%3D%20%26lt%3B480%26gt%3B%3B%20%2F*%20tvd%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F*%20%E6%B0%B4%E5%B9%B3%E6%96%B9%E5%90%91%20(th)%3A%20%E6%9C%80%E5%B0%8F%E5%80%A4%E3%81%8B%E3%82%89%E6%9C%80%E5%A4%A7%E5%80%A4%E3%81%BE%E3%81%A7%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%AE%E5%80%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AE%E6%A8%99%E6%BA%96%E5%90%88%E8%A8%88%E3%81%AF%20858%20%E3%81%A7%E3%81%99%20*%2F%3CBR%20%2F%3E%20hfront-porch%20%3D%20%26lt%3B28%26gt%3B%3B%20%2F*%20%E5%85%A8%E4%BD%93%E3%81%AE%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E8%AA%BF%E6%95%B4%20*%2F%3CBR%20%2F%3E%20hsync-len%20%3D%20%26lt%3B10%26gt%3B%3B%20%2F*%20thpw%20(%E7%AF%84%E5%9B%B2%206-14)%20*%2F%3CBR%20%2F%3E%20hback-porch%20%3D%20%26lt%3B20%26gt%3B%3B%20%2F*%20thbp%20(%E7%AF%84%E5%9B%B2%2014-34)%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F*%20%E5%9E%82%E7%9B%B4%20(tv)%3A%20%E6%9C%80%E5%B0%8F-%E6%9C%80%E5%A4%A7%E7%AF%84%E5%9B%B2%E3%81%AE%E5%80%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AE%E6%A8%99%E6%BA%96%E5%90%88%E8%A8%88%20488%20*%2F%3CBR%20%2F%3E%20vfront-porch%20%3D%20%26lt%3B5%26gt%3B%3B%20%2F*%20ttvfp%20(%E7%AF%84%E5%9B%B2%205-41)%20*%2F%3CBR%20%2F%3E%20vsync-len%20%3D%20%26lt%3B2%26gt%3B%3B%20%2F*%20tvpw%20(%E7%AF%84%E5%9B%B2%201%20%EF%BD%9E%202)%20*%2F%3CBR%20%2F%3E%20vback-porch%20%3D%20%26lt%3B1%26gt%3B%3B%20%2F*%20tvbp%20(%E7%AF%84%E5%9B%B2%203-4%E3%80%81tv%20%E5%90%88%E8%A8%88%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E8%AA%BF%E6%95%B4)%20*%2F%3C%2FP%3E%3CP%3E%2F*%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%206.6%20%E3%83%91%E3%83%BC%E3%82%B5%E3%83%BC%E3%81%AE%E5%BF%85%E9%A0%88%E6%A5%B5%E6%80%A7%E3%83%95%E3%83%A9%E3%82%B0%20*%2F%3CBR%20%2F%3E%20hsync-%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20vsync-active%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%E9%9D%9E%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%E3%83%9D%E3%83%BC%E3%83%88%20%7B%3CBR%20%2F%3E%20panel_lvds_in%3A%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%7B%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%20%26lt%3B%26amp%3Bldb_out%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%2F*%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AE%E7%AB%B6%E5%90%88%E3%82%92%E9%81%BF%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%20%2Fdelete-node%2F%20%26amp%3Blvds_bridge%3B%3C%2FP%3E%3CP%3E%26amp%3Bldb_phy%20%7B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%26amp%3Bldb%20%7B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3CBR%20%2F%3E%20%2F*%20'%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F'%20%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_VIDEO_PLL1_OUT%26gt%3B%2C%3CBR%20%2F%3E%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_MEDIA_LDB%26gt%3B%2C%3CBR%20%2F%3E%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_MEDIA_DISP2_PIX%26gt%3B%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A6%AA%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_VIDEO_PLL1_BYPASS%26gt%3B%2C%3CBR%20%2F%3E%20%26lt%3B%26amp%3Bclk%20IMX8MP_VIDEO_PLL1_OUT%26gt%3B%2C%3CBR%20%2F%3E%20%26lt%3B%26amp%3Bclk%20IMX8MP_VIDEO_PLL1_OUT%26gt%3B%3B%3C%2FP%3E%3CP%3Elvds-%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%400%20%7B%3CBR%20%2F%3E%20fsl%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20%3D%20%22jeida-24%22%3B%3CBR%20%2F%3E%20fsl%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E5%B9%85%20%3D%20%26lt%3B24%26gt%3B%3B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FP%3E%3CP%3E%2F*%20%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AB%E5%86%8D%E3%83%9E%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%20%2Fdelete-node%2F%20%E3%83%9D%E3%83%BC%E3%83%88%401%3B%3CBR%20%2F%3E%E3%83%9D%E3%83%BC%E3%83%88%401%20%7B%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20ldb_out%3A%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%7B%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%20%26lt%3B%26amp%3Bpanel_lvds_in%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%2F*%20i.MX8MP%E3%81%AELVDS%E3%81%AB%E3%81%AFLCDIF3%E3%81%8C%E5%BF%85%E9%A0%88%E3%81%A7%E3%81%99%20*%2F%3CBR%20%2F%3E%20%26amp%3Blcdif3%20%7B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%26amp%3Bhdmi%20%7B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E7%84%A1%E5%8A%B9%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
