LVDS data input
LVDS data input
1,883件の閲覧回数
olmscheid94
for a project I need to connect a CMOS image sensor with an AP or MCU. The data output of the sensor is LVDS. After some research I saw that the i.MX 6 SoloX has an LVDS interface. In the datasheet is mentioned that this interface is for connecting a display but is it possible to use it as data input?
Thanks for your help!
2 返答(返信)
1,776件の閲覧回数
AldoG
Unfortunately no, i.MX6 does not support LVDS inputs. It supports MIPI interface cameras, such as OV5640 that can be used with i.MX6.
Hope this helps,
Aldo.
1,776件の閲覧回数
olmscheid94
Hi Aldo,
this helps me a lot. Thank you for your support!
Alex
