LTIB & make options
已解决
LTIB & make options
跳至解决方案
2,833 次查看
TomMorrison
I want LTIB to use the '-j' option in calling make when building my image.
Is there something in LTIB I can tweak (even by hand)?
tom
标签 (2)
标记 (1)
1 解答
2,532 次查看
michaeldiamond
Try looking in the *.spec file in ltib/dist/lfs-5.1 folder.  I believe make is called from that file.
在原帖中查看解决方案
3 回复数
2,532 次查看
YixingKong
Senior Contributor IV
TomMorrison, if your question has been answered,please select Correct Answer so that the DI will be closed.
2,532 次查看
TomMorrison
I have not tried it yet, so I can't say for sure...:-)
2,533 次查看
michaeldiamond
