LTIB for iMX25 installation error - need help
3,395 次查看
arumugamramasam
I am using Ubuntu 9.04 and when i un-tar the LTIB source files and try to run the install script, i am facing error message as attached. Need help to successfully install the LTIB for iMX25. Error messages showing a few packages missing.
Arumugam R
3,084 次查看
saurabh206
Senior Contributor III
LTIB requires some package to be installed on your UBUNTU machine.
You can use sudo apt-get install m4 bison patch tcl rpm rpm-build.
You can check follow link for LTIB installation.
https://community.freescale.com/docs/DOC-1442
Saurabh
PicusTech Software
3,085 次查看
saurabh206
Saurabh
PicusTech Software
3,084 次查看
arumugamramasam
Hi Saurabh,
Thanks for the information… I am able to install the necessary packages and now LTIB configuration is going on. Thanks once again…
Arumugam R
