LTIB and make
LTIB and make
2,214 次查看
Filippo
Hi all,
this is only to share some informations.
I'm using Fedora16, with L2.6.35_11.09.01_ER_source_bundle for the START_R board.
gstreamer fails to compile inside ltib, complaining about a Makefile corrupt.
Fedora16 has make 3.82.
Changing make to version 3.81 solves the problem, and the build finishes with success.
sparse-0.4 has a problem too, in the parse.h file.
I have removed some lines in parse.h as explained here , and everything compiles fine.
On a Ubuntu 12.04 installation, the make is a 3.81, so it's ok, but the sparse problem is there.
Cheers
Filippo
标签 (1)
标记 (2)
2 回复数
1,951 次查看
LeonardoSandova
Specialist I
Thanks for your sharing this info. Do you know what changed from 3.81 to 3.82 which introduced this error?
Leo
1,951 次查看
wangtuo
Hello, I have the same problem. I have seen your explain,but I  don't know what should I do .Can you explain it in detail? thank you
