LPDDR4 vs DDR4 with iMX8M Mini
2,389件の閲覧回数
alexanderpdx
What is the actual difference in power consumption (absolute and/or percentage) between using LPDDR4 vs DDR4? I can see that there are 2 EVK designs that differ in this regard, so measurements might have been done. I'm trying to determine if the power savings are worth the extra cost of LPDDR4. Thank you.
1,998件の閲覧回数
gusarambula
Hello Alexander Khvilivitzky,
The i.MX8M Mini is currently in preproduction status so I would need to ask you to please contact your Distributor or FAE to inquiry about available technical information for the i.MX8M Mini.
My apologies for the inconvenience!
