LIN support in IMX
LIN support in IMX
1,646 次查看
wasim_nazir
Is there any LIN driver support in imx? Is it SPI based or UART based?
1 回复
1,617 次查看
Bio_TICFSL
Hello Wasim,
i.MX6 devices do not support LIN in physical layer as they don't provide PHY. However, the UART module can be configured to 13-bit and it will be able to work as LIN in Data-Link layer, then you only need to connect with external LIN PHY.
