Kernel stuck on systemd Journal Service
1,224件の閲覧回数
dpog
Contributor V
My Kernel is stuck at this point at boot, any suggestions, what might be the cause?
Welcome to Wayland (XWayland) Distribution (dunfell)!
[ 2.722966] systemd[1]: Set hostname to <imx8mm-eva-mi>.
[ 3.011527] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.018330] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 3.030694] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 3.041556] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 3.054054] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.061656] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 3.084914] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.092488] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 3.116865] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 3.140363] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 3.164343] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 3.184919] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 3.208620] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 3.228919] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 3.254812] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 3.276671] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 3.297126] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 3.321203] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 3.333938] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 3.357277] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 3.376774] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 3.400986] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 3.413653] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 3.440202] systemd[1]: Mounting Huge Pages File System...
[ 3.463542] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.495358] systemd[1]: Mounting Kernel Debug File System...
[ 3.525994] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 3.551651] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st…odes for the current kernel...
[ 3.583828] systemd[1]: Starting RPC Bind...
[ 3.600761] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 3.614351] systemd[1]: Starting Journal Service...
[ 3.637280] systemd[1]: Starting Load Kernel Modules...
[ 3.663580] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.669627] galcore: loading out-of-tree module taints kernel.
[ 3.687556] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 3.688484] galcore: clk_get vg clock failed, disable vg!
[ 3.693734] systemd[1]: Starting udev Coldplug all Devices...
[ 3.698894] Galcore version 6.4.0.234062
[ 3.725356] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 3.735695] systemd[1]: Started Journal Service.
[ 3.740838] audit: type=1701 audit(1600598639.112:2): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=252 comm="udevadm" exe="/bin/udevadm" sig=4 res=1
タグ(1)
0 返答(返信)
