Kernel panic - not syncing: Attempted to kill the idle task!
Foxbat25
Hello NXP
I am using iMX8M mini with sd card and eMMC (SDINBDG4-32G-XI1) while booting it from sd card it is working fine, but while booting from eMMC it is giving "Kernel panic - not syncing: Attempted to kill the idle task!".
what could be the possible reason.
JorgeCas
Hello, I hope you are doing well.
Are you using a custom board?
Could you please share the eMMC schematic diagram section?
Also, please share the logs including U-boot logs.
Best regards.
