Issues about PM Debug on IMX6DL
2,043件の閲覧回数
tony_l_cai
Dear all,
     I have read the article  Android Power Management on i.MX6DQ/DL
and  “All PLLs will cut off, just 32KHZ sleep clock living (FSL done)” ,how to check?
could you give me more in details?
Thank you~
ラベル(3)
3 返答(返信)
1,604件の閲覧回数
Hi tony
one can output necessary clock to CLKO1,2 pin and check
it by oscilloscope using register CCM_CCOSR, add debug code
to sources or use memtool for writing to CCM_CCOSR.
1,604件の閲覧回数
tony_l_cai
Hi Igor,
     If I find Some PLLs isn't cut off, how to cut off?
3Q~
1,604件の閲覧回数
Hi tony
one can follow procedure described in sect.18.5.3.3 STOP mode
IMX6SDLRM
~igor
