Is there any idea to use both ENET2 and EIM simultaneously for i.MX7D?
960 次查看
torus1000
Contributor V
I checked i.MX7D pins with PinTool v.4.0 then found conflictions between ENET2(RGMII2) and EIM(AD21-10).
In this case, very restricted address pins were availabe for EIM such as {A27-A22,A9-A0}.
If I changed the mode from RGMII to RMII, 4 more pins could be available as following.
{A27-A22,A19,A18,A13,A12,A9-A0}
Obviously it is not convenient for me anyway because I need to access 8Mb SRAM thru EIM.
How can I avoid this conflictions; ENET2(RGMII2) and EIM(AD21-10)?
Is there any idea to use both ENET2 and EIM simultaneously?
Can anyone help me?
819 次查看
Yuri
  As I see, it is not possible to configure i.MX7 for Your purposes, since some RGMII2
and EIM signals have only single (conflicting) multiplexing option. Look at section 8.1.1.1
(Muxing Options) of the i.MX7D RM (Rev. 1, 01/2018).
Yuri
820 次查看
Yuri
Yuri
