I checked i.MX7D pins with PinTool v.4.0 then found conflictions between ENET2(RGMII2) and EIM(AD21-10).
In this case, very restricted address pins were availabe for EIM such as {A27-A22,A9-A0}.
If I changed the mode from RGMII to RMII, 4 more pins could be available as following.
{A27-A22,A19,A18,A13,A12,A9-A0}
Obviously it is not convenient for me anyway because I need to access 8Mb SRAM thru EIM.
How can I avoid this conflictions; ENET2(RGMII2) and EIM(AD21-10)?
Is there any idea to use both ENET2 and EIM simultaneously?
Can anyone help me?
