Is the EdgeLock SE050 Development Kit compatible with the i.MX8MQ EVK?
2,548件の閲覧回数
goescy
Hi all
The title says it. Our business cases likely require us to use EdgeLock and we work with the i.MX8MQ EVK. Is the EdgeLock SE050 Development Kit compatible with this i.MX8MQ EVK?
Many thanks for your inputs.
Cyrill
3 返答(返信)
2,508件の閲覧回数
goescy
Great. Many thanks for your answer.
How would I connect the EdgeLock SE050 Development kit to an i.MX8MQ EVK?
Best wishes,
Cyrill
2,508件の閲覧回数
Rita_Wang
You can try to Enabled i2c-1 module for connecting SE050. And I found a patch for software, hope can do help for you.https://community.nxp.com/message/1277468
2,508件の閲覧回数
Rita_Wang
EdgeLock SE050 works as a companion chip to any type of MCU or MPU, communication is over the I2C bus.
I found this Industrial & IoT Vertical Priority: Implementing Latest IoT Security Use Cases with NXP’s EdgeLo...
EdgeLock™ SE050: NXP’s New Generation Plug & Trust Solution to Secure IoT Edge
Hope can do help for you
