Interfacing DDR3 memory having higher data rate with i.MX6ULZ.
With reference to the attached data from i.MX6 ULZ datasheet- DDR3 supports upto 400MHz clock rate with single channel.
Kindly confirm whether this can be down converted from the memory side for the below mentioned parts
Micron -- MT41J128M16JT-093:K TR
Windbond -- W632GG6MB-12 TR
