Hi All,
I am in the process of developing a dummy audio codec driver to interface a transceiver modem which is connected through I2S to SAI3 interface of iMX6ULL.
Here modem is acting as master and CPU slave as the modem CLK line is output.
Could you help me get some reference dummy audio codec driver and the device tree structure for the same?
Kiran
Hi kmagi
for dummy audio codec one can look at below patch
<correcting subject line from SAI3 to SAI2>
How can I configure/reflect modem parameters,
