Install LibUSB on UCM-IMX93 error
1,431 次查看
Selwyn
I am trying to install libusb on the UCM-IMX93 development board by using this line:
sudo apt-get install libusb-1.0-0-dev
However, I get this error:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package libusb-1.0-0-dev
E: Couldn't find any package by glob 'libusb-1.0-0-dev'
E: Couldn't find any package by regex 'libusb-1.0-0-dev'
May I get some help in deciphering what is wrong?
1 回复
1,411 次查看
Rita_Wang
Which version BSP are you using? Here you want to use uuu to download images or build the source code?
