I'm trying to activate pins (on my IMX8MQ), such as MIPI_CSI1. Firstly, why is it grayed out by default?
Then when I activate it, I route all the corresponding pins, but these are added as comments in the pin_mux.dts, instead of being in the fsl, pins with a hex code.
Thanks in advance,
Best regards.
Hello @Hpot
Th commented lines belong to YAML SETTIGS for Config tools. As MIPI signals have dedicated pins there is not necessary to config "IOMUX".
Best regards.
Salas.
But then how can I configure this type of pins? Are they “stuck” in this configuration?
