Imx6q receiving data through ssi
2,994件の閲覧回数
hsl
Hello everyone:
I would like to ask:
Imx6q connects to the external i2s signal through audmux3. How can I configure the i2s data to be received through the ssi interface?
Just like this connection, there is no ssi codec, only three signal lines are connected to audmux:
Thank you~
2 返答(返信)
2,910件の閲覧回数
igorpadykov
Hi H
in general such connection is possible, example of ssi-audmux programming
one can find in AN2628 Programming Audio Applications
https://www.nxp.com/docs/en/application-note/AN2628.pdf
2,910件の閲覧回数
hsl
Hi,Igorpadykov:
Thank you for your reply!
The AN2628 programming audio application you said in the reply did not find it. The link is just a chip introduction manual.
Now I am connected like this, but how do I configure it to read the i2s signal? Seeking advice!
Thank you
