Imx53 - Android - SD
3,410件の閲覧回数
mntmrk
I have an Android 2.3.4 application on Imx53 on SD. I have about 100 system and after some month I have problem in filesystem.
Some files and directory are corrupted and lost so system crash: i.e. Adobe flash palyer files stoterd in /data/data/com.adobe.flashpalyer/ directory are destroied!
Has someone expirence about this kind of problem using SD card?
I have programmed SD making a phisical clone of a same SD. Is this procedure safety?
ラベル(2)
タグ(3)
6 返答(返信)
3,233件の閲覧回数
YixingKong
Senior Contributor IV
Mirko
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this
discussion, or create another discussion.
Yixing
3,233件の閲覧回数
YixingKong
Mirko
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help please feel free to contact Freescale.
Yixing
3,233件の閲覧回数
charleschang
This may happen if system power off directly, and the filesystems are not unmount properly.
3,233件の閲覧回数
mntmrk
How to "unmount properly"?
I can't unmount any partition cause partitions are busy.....
reboot o poweroff command seems not unmount partition before system power off!
3,233件の閲覧回数
charleschang
follow the android standard procedure -- power off.
before shutting down, the system will sync and unmount all storage devices.
3,233件の閲覧回数
mntmrk
The power off is no directly and I close system before power it down.
It seems that ext4 filesystem is corrupted!
mksf.ext4 -cc on SD partition doesn't show any error on SD.
