Idle Lin Detection Interrupt.
abdrhmn
I would like to implement idle line detection. I already configured the interrupt. When this flag is set I called LPUART_TransferAbortReceiveEDMA to stop the receiving. However, it doesn't call the LPUART_ReceiveEDMACallback. Is this expected?
By the way, I'm using iMX8ULP
AldoG
Are you working on the A35 or the M33?
Could you share the SDk/BSP version you are using?
Best regards/Saludos,
Aldo.
