ISP support for iMX95 FRDM Evaluation kit
Harish_V
Hi Team,
I am trying to port a Bayer sensor on the i.MX95 FRDM platform. Following the software setup guide below, I was able to connect and stream video using the NXP-supported OS08A20 camera module which was provided in the NXP website.
Now, I would like to port and stream a different Bayer sensor. Is there any documentation available that explains:
  • Where to obtain the libcamera source code and how to build it for the i.MX95 platform?
  • How to generate ISP-specific YAML and configuration files for a new Bayer sensor?
  • What camera driver parameters and controls are required to support a Bayer sensor on the i.MX95 FRDM platform?
  • The complete software flow for integrating a new Bayer sensor with the NXP ISP pipeline?
Can you please let me know at the earliest. Thanks
AldoG
Please refer to the following guide:
https://www.nxp.com/docs/en/user-guide/UG10215.pdf
Best regards/Saludos,
Aldo.
%3CLINGO-SUB%20id%3D%22lingo-sub-2383524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EISP%20support%20for%20iMX95%20FRDM%20Evaluation%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Team%2C%3CBR%20%2F%3EI%20am%20trying%20to%20port%20a%20Bayer%20sensor%20on%20the%20i.MX95%20FRDM%20platform.%20Following%20the%20software%20setup%20guide%20below%2C%20I%20was%20able%20to%20connect%20and%20stream%20video%20using%20the%20NXP-supported%20OS08A20%20camera%20module%20which%20was%20provided%20in%20the%20NXP%20website.%3C%2FP%3E%3CP%3ENow%2C%20I%20would%20like%20to%20port%20and%20stream%20a%20different%20Bayer%20sensor.%20Is%20there%20any%20documentation%20available%20that%20explains%3A%3C%2FP%3E%3CUL%3E%3CLI%3EWhere%20to%20obtain%20the%20libcamera%20source%20code%20and%20how%20to%20build%20it%20for%20the%20i.MX95%20platform%3F%3C%2FLI%3E%3CLI%3EHow%20to%20generate%20ISP-specific%20YAML%20and%20configuration%20files%20for%20a%20new%20Bayer%20sensor%3F%3C%2FLI%3E%3CLI%3EWhat%20camera%20driver%20parameters%20and%20controls%20are%20required%20to%20support%20a%20Bayer%20sensor%20on%20the%20i.MX95%20FRDM%20platform%3F%3C%2FLI%3E%3CLI%3EThe%20complete%20software%20flow%20for%20integrating%20a%20new%20Bayer%20sensor%20with%20the%20NXP%20ISP%20pipeline%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3ECan%20you%20please%20let%20me%20know%20at%20the%20earliest.%20Thanks%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ISP%20support%20for%20iMX95%20FRDM%20Evaluation%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3EPlease%20refer%20to%20the%20following%20guide%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FUG10215.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FUG10215.pdf%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20regards%2FSaludos%2C%3CBR%20%2F%3EAldo.%3C%2FP%3E%3C%2FLINGO-BODY%3E
