IPU ipulib.shm issue
已解决
跳至解决方案
2,189 次查看
johnturnur
I want to user IPU in my andriod based system.
i have setup a simple test using mxc_ipu_lib_ipc_init().
I got follwoing error
"Can not open the shared memory for /mnt/shm/ipulib.shm!"
How to solve this issue?
John
1 解答
2,047 次查看
jimmychan
I think you can take the i.MX unit_test for reference. There is an test example for ipu.
You can extract the package by this LTIB command.
./ltib -p imx-test -m prep
Then you can find the source code be extracted in ltib/rpm/BUILD/.
在原帖中查看解决方案
2 回复数
2,048 次查看
jimmychan
2,047 次查看
johnturnur
Jimmy
Thanks for your reply.
I have build imx-test.
./rpm/BUILD/imx-test-09.12.01
It build for IMX35_3STACK.
I have port customized file system to IMX35.
But no IPU device is available in my kernel, so  i need to enable that.
Can you please suggest me what changes is required to enable IPU in kernel and
fixed ipulib.shm issue.
John
