IMXRT1160 Altium Design File
1,842 次查看
JSuciu
Does anyone have the ASCII format PCB files for the MIMXRT1160-EVK please?
I can't import the .brd file into Altium and I don't have access to Allegro.
It would be nice if the ASCII format file was always put in with the EVK Layout files.
4 回复数
1,810 次查看
JSuciu
The only way to convert into Altium files is with the ASCII (.alg) Allegro file, which is created in Allegro (using Cadence's extracta.exe utility). I do not have Allegro, so I am unable to perform this conversion myself. I've seen threads similar to this on other product lines where tech support was able to email out the .alg version. I would appreciate the same being done for the MIMXRT1160.
1,790 次查看
Pavel_Hernandez
Hello, yes, there are some cases where the RT Altium design files was shared, but the file was made when we had Altium License, we do not have all design of new EVK.
Pavel
1,814 次查看
Pavel_Hernandez
Hello, I confirm we do not have the MIMXRT1160 design files in Altium format. Just the files that are available on the link that I passed before.
Pavel
1,818 次查看
Pavel_Hernandez
Hello, I will be supporting your case, I recommend find design files on the next link.
Microcontroller Symbols, Footprints and Models | NXP Semiconductors
Let me get more details about the ASCII format.
Pavel
