IMXRT1062 ROM API
IMXRT1062 ROM API
divithsid
I'm using ROM API to store the critical data into flash.
As I tried with reading 1kb, writing 256bytes and erasing 4kb works fine. but when I increased reading size to 2kb the system restarts. Kindly let me know what is the max size for read using these API.
Note: flash IC data sheet mentioned we can read entire memory using 1 instruction.
iMXRT1060
jingpan
Hi @divithsid ,
I increase the size to 4096. But it woks fine. Here is my code.
Jing
