IMXRT1052 how to decode PNG image's "RAW_ALPHA" colo format C array with LVGL
vwsncr
       Now i can decode JPG images with LVGL,but  the display show "no data" when using the same way to decode PNG images.
jingpan
Hi @vwsncr,
I tested online converter, it works fine for PNG file. Maybe you can try the offline version.
Jing
jingpan
Hi @vwsncr,
Jing
vwsncr
Hi , @jingpan
    Thanks for reply!
    I have solved the problem . I tested different package of PNG decoder. The newest one (v8.3.0)works very well. But the JPG decoder package , i used old version from SDK's example. Do you think it is a good way?
vwsncr
jingpan
Hi @vwsncr ,
No problem.
Jing
