IMXRT1050EVKB SDCARD and USB Integration
1,153 次查看
AkshayWale
I am using IMXRT1050EVKB , MCUxpressso v11.4.1 and SDK 2.10.0
SDcard and Pendrive SDK  examples are Individualy working fine in IMXRT1050.
I have integrated SDcard and USB code in the main software, SDcard is working absoultely fine but when i attach the pendrive to J9 , all content that need to write in sdcard is writing in usb which is not required.
How to control both? and How to differenciate USB and SDCard?
Akshay
1,135 次查看
jingpan
Hi @AkshayWale ,
SDcard and USB have different stack. Maybe you should check if they shared same buffer or RAM space?
Jing
