IMX93 RS485 Multidrop support
505 次查看
EmbeddedFox
We are using the IMX93 in one of our projects that require RS485 with multidrop.
The IMX93 is placed upon a SOM-module from Variscite, and the kernel is based upon
the kernel from NXP.
Looking at the kernel documentation, it has a disclaimer that not all devices supporting RS485
does support multipoint addressing.
(https://docs.kernel.org/driver-api/serial/serial-rs485.html)
Is there any plan to implement RS485 multipoint addressing in the Kernel
标记 (1)
424 次查看
Rita_Wang
Are you using NXP i.MX93 EVK board or the board you design yourself? Which version BSP are you using?
409 次查看
EmbeddedFox
We are using a development kit from Variscite at the moment, but are in the progress of designing our own board.
https://www.variscite.com/product/system-on-module-som/cortex-a55/var-som-mx93-nxp-i-mx-93/#evaluati...
Also, the Kernel we are using is from Variscite, but as I understand it, it is based upon NXPs BSP.
https://github.com/varigit/linux-imx/tree/lf-6.1.y_var02
Their customer support referred us here.
