Hi @Navya ,
Q1&A:This is the maximum possible current consumed on these pins in the FRDM board design.
For the maximum current of VDD_SOC in i.MX93 is 2700 mA. So for the FRDM is the lower power design. So if you have the same requirement, you can refer to it.
If no, you can refer to the i.MX93 EVK design.
For the right side power, you can calculate, it is the approximately you refer to :
Q2&A:Both follow the same i.MX93 series power supply architecture.
Hope this can do help for you
Wish you have a nice day
Best Regards
Rita
