IMX93 Custom board build error
2,496 次查看
Saravanans1
We are encountering errors when running bitbake imx image full during our IMX93 custom build. Could you please provide a solution at your earliest convenience? We are using imx 6.6.52 version.
S.Saravanan
5 回复数
2,475 次查看
Chavira
HI @Saravanans1!
Thank you for contacting NXP Support!
Do you create a new machine config for your project?
Looks like is not including the compiled binary of the M core examples, but are not necessary.
You can see the imx93evk.conf that includes the binaries you can delete the binaries in your config file.
Check your llayer.conf too.
I recommend to check our IMX PORTING GUIDE for more details.
Best Regards!
Chavira
2,384 次查看
Saravanans1
Hi Chavira,
We are trying to build Yocto 6.6.23 on the IMX93Evk, but we have encountered build issues as mentioned in the link below.
https://community.nxp.com/t5/i-MX-Processors/i-MX93-meta-imx-broken-due-to-rogue-change-of-firmware-...
Although we applied the patch suggested in the link, we are still unable to successfully build the 6.6.23 Yocto version. If the issue has been resolved, could you please provide the solution?
Thanks & Regards,
Saravanan
2,332 次查看
Chavira
Hi @Saravanans1!
Can you try again?
Try to delete your current project and start a new one.
I try by my side and the problem should be solved now.
Best Regards!
Chavira
2,375 次查看
Chavira
Hi @Saravanans1!
Try patching the source
Notice that this is not fully test by NXP.
Best Regards!
Chavira
2,350 次查看
Saravanans1
Hi Chavira,
We have tried this patch even though not working. Is there any other solution available?
