IMX8mq not support L4.914.98 ?
765 次查看
cotway
 download yocto  by:
   mkdir imx-yocto-bsp
cd imx-yocto-bsp
 repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-sumo -m imx-4.14.98-2.0.0_ga.xml
 repo sync
but,no MACHINE support imx8mqevk
760 次查看
Rita_Wang
This version BSP support the i.MX8MQ, if you have finished the repo sync, you can go next steps to build images for the i.MX8MQ:
$ DISTRO=fsl-imx-wayland MACHINE=imx8mqevk source fsl-setup-release.sh -b build-wayland
$ bitbake fsl-image-qt5-validation-imx
This builds a Qt 5 Weston Wayland image. To build without Qt 5, build fsl-image-validation-imx.
Details you can refer to the i.MX_Yocto_Project_User's_Guide document.
761 次查看
Rita_Wang
753 次查看
cotway
thanks.I had found.
