IMX8X QXP - ENET mapping
1,258 次查看
lionel_augros_thales
In the IMX8X reference manual IMX8DQXPRM in the Table 2-5. Connectivity memory map the following mappings are given :
ENET-AVB2 at base adress 5B05_0000
ENET-AVB1 at base adress 5B04_0000
Can you confirm that ENET-AVB2 corresponds to ENET1 controller and ENET-AVB1 corresponds to ENET0  controller ?
Thanks in advance,
Lionel A.
1,237 次查看
riteshmpatel
Hi @lionel_augros_thales,
Yes, your understanding is correct.
One can refer to https://github.com/nxp-imx/linux-imx/blob/lf-6.1.y/arch/arm64/boot/dts/freescale/imx8-ss-conn.dtsi.
Thanks & Regards,
Ritesh M Patel
