IMX8QM: Serial ports registered but /dev/ttyLP1 is missing
已解决
跳至解决方案
1,989 次查看
vinothkumars
Senior Contributor IV
I had the issue I unable to find the device entry for LPUAR1 - ttyLP1.
Here is the debug message,
[ 1.732363] 5a070000.serial: ttyLP1 at MMIO 0x5a070010 (irq = 65, base_baud = 5000000) is a FSL_LPUART
[ 1.741833] serial serial0: tty port ttyLP1 registered
Vinothkumar Sekar
标记 (5)
1 解答
1,979 次查看
vinothkumars
Hi All,
finally, I found the fix. This uart interface is allocated to chipset by default in dts.
Vinothkumar Sekar
在原帖中查看解决方案
标记 (2)
1 回复
1,980 次查看
vinothkumars
Hi All,
Vinothkumar Sekar
标记 (2)
