IMX8QM MIPI CSI MINISASTOCSI camera module
1,226件の閲覧回数
fsed
i have a problem to run the MINISASTOCSI camera module with kernel 5.10 on MEK evalboard, is there any known issue, because with kernel 4.14 it is running without problems.
https://www.nxp.com/part/MINISASTOCSI#/
https://www.nxp.com/design/development-boards/i-mx-evaluation-and-development-boards/i-mx-8quadmax-m...
thanks
1,199件の閲覧回数
joanxie
what problem do you have? did you use nxp board or customized board? did you use demo images or your own built images? share your test steps
