IMX8MP galcore_deamon Undefined instruction
917件の閲覧回数
James33
Dear NXP Technical Support Team,
Hello!
BOARD: IMX8MP
Yocto: scarthgap 6.6.23
On the i.MX8mp development board, I encountered this error.
## imx8mp-lpddr4-evk kernel: Internal error: Oops - Undefined instruction: 0000000002000000 [#1] PREEMPT SMP
## imx8mp-lpddr4-evk kernel: Modules linked in: fsl_jr_uio caam_jr caamkeyblob_desc caamhash_desc caamalg_desc crypto_engine authenc libdes crct10dif_ce polyval_ce polyval_generic snd_soc_fsl_asoc_card dw_hdmi_cec snd_soc_fsl_sai snd_soc_fsl_micfil snd_soc_fsl_xcvr imx8_media_dev(C) snd_soc_imx_audmux snd_soc_fsl_aud2htx snd_soc_fsl_easrc snd_soc_fsl_utils snd_soc_fsl_asrc imx_pcm_dma rtc_ds1307 snd_soc_wm8962 caam secvio error imx_dsp_rproc xt_conntrack nf_conntrack nf_defrag_ipv4 iptable_filter fuse
## imx8mp-lpddr4-evk kernel: CPU: 3 PID: 79 Comm: galcore_deamon/ Tainted: G         C         6.6.23-lts-next-dirty #1
## imx8mp-lpddr4-evk kernel: Hardware name: YTX FT Release Distro (DT)
## imx8mp-lpddr4-evk kernel: pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
## imx8mp-lpddr4-evk kernel: pc : dma_fence_signal+0x58/0x64
## imx8mp-lpddr4-evk kernel: lr : gckOS_Signal+0x180/0x244
## imx8mp-lpddr4-evk kernel: sp : ffff800082a6bd00
## imx8mp-lpddr4-evk kernel: x29: ffff800082a6bd10 x28: 0000000000000000 x27: ffff800082a6be10
## imx8mp-lpddr4-evk kernel: x26: 0000000000000000 x25: ffff800081b3c008 x24: ffff000026b7f3c4
## imx8mp-lpddr4-evk kernel: x23: ffff0000d1b6c1e0 x22: ffff0000d0d64044 x21: 0000000000000000
## imx8mp-lpddr4-evk kernel: x20: ffff0000d0d64048 x19: ffff000026b7f3c0 x18: 0000000000000000
## imx8mp-lpddr4-evk kernel: x17: 0000000000000000 x16: 0000000000000000 x15: 0000ffff8db25538
## imx8mp-lpddr4-evk kernel: x14: 0000000000000000 x13: 0000000000000209 x12: 0000000000000002
## imx8mp-lpddr4-evk kernel: x11: 0000000000000040 x10: ffff0000d0d64050 x9 : ffff0000d0d64048
## imx8mp-lpddr4-evk kernel: x8 : ffff000006433b78 x7 : 0000000000000000 x6 : 000002a5fe056003
## imx8mp-lpddr4-evk kernel: x5 : 00ffffffffffffff x4 : ffff0000d1b6c210 x3 : 0000000000000000
## imx8mp-lpddr4-evk kernel: x2 : 0000000000000000 x1 : ffff0000d02b6740 x0 : 0000000000000000
## imx8mp-lpddr4-evk kernel: Call trace:
## imx8mp-lpddr4-evk kernel:  dma_fence_signal+0x58/0x64
## imx8mp-lpddr4-evk kernel:  gckOS_UserSignal+0x7c/0xb0
## imx8mp-lpddr4-evk kernel:  gckEVENT_Notify+0x21c/0x410
## imx8mp-lpddr4-evk kernel:  gckHARDWARE_Notify+0x68/0xc8
## imx8mp-lpddr4-evk kernel:  gckKERNEL_Notify+0x20/0x2c
## imx8mp-lpddr4-evk kernel:  threadRoutine+0x1c/0x78
## imx8mp-lpddr4-evk kernel:  kthread+0x110/0x114
## imx8mp-lpddr4-evk kernel:  ret_from_fork+0x10/0x20
## imx8mp-lpddr4-evk kernel: Code: 2a1303e0 a94153f3 a8c27bfd d50323bf (d65f03c0)
## imx8mp-lpddr4-evk kernel: ---[ end trace 0000000000000000 ]---
According to "dma_fence_signal+0x58/0x64", I checked the "dma_fence_signal" function and found that the instruction corresponding to the 0x58 position is the "ret" instruction.
file path: imx8mp-xwayland/tmp/work-shared/imx8mp-lpddr4-evk/kernel-source/drivers/dma-buf/dma-fence.c
int dma_fence_signal(struct dma_fence *fence)
	unsigned long flags;
	int ret;
	bool tmp;
	if (!fence)
		return -EINVAL;
	tmp = dma_fence_begin_signalling();
	spin_lock_irqsave(fence->lock, flags);
	ret = dma_fence_signal_timestamp_locked(fence, ktime_get());
	spin_unlock_irqrestore(fence->lock, flags);
	dma_fence_end_signalling(tmp);
	return ret;
EXPORT_SYMBOL(dma_fence_signal);
## aarch64-linux-gnu-objdump -r -d vmlinux | grep -A 30 \<dma_fence_signal\>:
ffff8000809bcfe8 <dma_fence_signal>:
ffff8000809bcfe8:	d503233f 	paciasp
ffff8000809bcfec:	a9be7bfd 	stp	x29, x30, [sp, #-32]!
ffff8000809bcff0:	910003fd 	mov	x29, sp
ffff8000809bcff4:	a90153f3 	stp	x19, x20, [sp, #16]
ffff8000809bcff8:	b4000260 	cbz	x0, ffff8000809bd044 <dma_fence_signal+0x5c>
ffff8000809bcffc:	aa0003f3 	mov	x19, x0
ffff8000809bd000:	f9400000 	ldr	x0, [x0]
ffff8000809bd004:	942b4fed 	bl	ffff800081490fb8 <_raw_spin_lock_irqsave>
ffff8000809bd008:	aa0003f4 	mov	x20, x0
ffff8000809bd00c:	97dd9d70 	bl	ffff8000801245cc <ktime_get>
ffff8000809bd010:	aa0003e1 	mov	x1, x0
ffff8000809bd014:	aa1303e0 	mov	x0, x19
ffff8000809bd018:	97ffff6e 	bl	ffff8000809bcdd0 <dma_fence_signal_timestamp_locked>
ffff8000809bd01c:	2a0003e2 	mov	w2, w0
ffff8000809bd020:	aa1403e1 	mov	x1, x20
ffff8000809bd024:	f9400260 	ldr	x0, [x19]
ffff8000809bd028:	2a0203f3 	mov	w19, w2
ffff8000809bd02c:	942b4eb5 	bl	ffff800081490b00 <_raw_spin_unlock_irqrestore>
ffff8000809bd030:	2a1303e0 	mov	w0, w19
ffff8000809bd034:	a94153f3 	ldp	x19, x20, [sp, #16]
ffff8000809bd038:	a8c27bfd 	ldp	x29, x30, [sp], #32
ffff8000809bd03c:	d50323bf 	autiasp
ffff8000809bd040:	d65f03c0 	ret
ffff8000809bd044:	128002b3 	mov	w19, #0xffffffea            	// #-22
ffff8000809bd048:	17fffffa 	b	ffff8000809bd030 <dma_fence_signal+0x48>
I would like to know why the "ret" instruction is causing the problem? And what should I do to avoid this error? This is an occasional occurrence. I don't yet know what kind of action caused this problem to happen. I am unable to manually reproduce this issue.
タグ(1)
2 返答(返信)
839件の閲覧回数
Zhiming_Liu
Hi @James33
Are you using the standard Linux kernel or PREEMPT Linux?
Zhiming
831件の閲覧回数
James33
The yocto version is scarthgap6.6.23. I did not make any modifications to the linux-imx_6.6.bb file, nor did I modify the galcore related drivers. I only modified the dts file of the kernel. So it should be the standard Linux kernel.Sometimes the error occurs in other functions, and dma_fence_signal is just one of them.
## zcat /proc/config.gz | grep PREEMPT
CONFIG_PREEMPT_BUILD=y
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
CONFIG_PREEMPT_COUNT=y
CONFIG_PREEMPTION=y
# CONFIG_PREEMPT_DYNAMIC is not set
CONFIG_PREEMPT_RCU=y
CONFIG_HAVE_PREEMPT_DYNAMIC=y
CONFIG_HAVE_PREEMPT_DYNAMIC_KEY=y
CONFIG_PREEMPT_NOTIFIERS=y
# CONFIG_DEBUG_PREEMPT is not set
%3CLINGO-SUB%20id%3D%22lingo-sub-2364422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20galcore_%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%91%BD%E4%BB%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2364422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%83%86%E3%82%AF%E3%83%8B%E3%82%AB%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%81%E3%83%BC%E3%83%A0%E6%A7%98%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%3A%20IMX8MP%3CBR%20%2F%3E%20Yocto%3A%20scarthgap%206.6.23%3C%2FP%3E%3CP%3Ei.MX8mp%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20Internal%20error%3A%20Oops%20-%20Undefined%20instruction%3A%200000000002000000%20%5B%231%5D%20PREEMPT%20SMP%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20Modules%20linked%20in%3A%20fsl_jr_uio%20caam_jr%20caamkeyblob_desc%20caamhash_desc%20caamalg_desc%20crypto_engine%20authenc%20libdes%20crct10dif_ce%20polyval_ce%20polyval_generic%20snd_soc_fsl_asoc_card%20dw_hdmi_cec%20snd_soc_fsl_sai%20snd_soc_fsl_micfil%20snd_soc_fsl_xcvr%20imx8_media_dev(C)%20snd_soc_imx_audmux%20snd_soc_fsl_aud2htx%20snd_soc_fsl_easrc%20snd_soc_fsl_utils%20snd_soc_fsl_asrc%20imx_pcm_dma%20rtc_ds1307%20snd_soc_wm8962%20caam%20secvio%20error%20imx_dsp_rproc%20xt_conntrack%20nf_conntrack%20nf_defrag_ipv4%20iptable_filter%20fuse%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20CPU%3A%203%20PID%3A%2079%20Comm%3A%20galcore_deamon%2F%20Tainted%3A%20G%20%20%20%20%20%20%20%20%20C%20%20%20%20%20%20%20%20%206.6.23-lts-next-dirty%20%231%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20Hardware%20name%3A%20YTX%20FT%20Release%20Distro%20(DT)%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20pstate%3A%2060000005%20(nZCv%20daif%20-PAN%20-UAO%20-TCO%20-DIT%20-SSBS%20BTYPE%3D--)%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20pc%20%3A%20dma_fence_signal%2B0x58%2F0x64%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20lr%20%3A%20gckOS_Signal%2B0x180%2F0x244%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20sp%20%3A%20ffff800082a6bd00%0A%09%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20x29%3A%20ffff800082a6bd10%20x28%3A%200000000000000000%20x27%3A%20ffff800082a6be10%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20x26%3A%200000000000000000%20x25%3A%20ffff800081b3c008%20x24%3A%20ffff000026b7f3c4%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20x23%3A%20ffff0000d1b6c1e0%20x22%3A%20ffff0000d0d64044%20x21%3A%200000000000000000%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20x20%3A%20ffff0000d0d64048%20x19%3A%20ffff000026b7f3c0%20x18%3A%200000000000000000%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20x17%3A%200000000000000000%20x16%3A%200000000000000000%20x15%3A%200000ffff8db25538%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20x14%3A%200000000000000000%20x13%3A%200000000000000209%20x12%3A%200000000000000002%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20x11%3A%200000000000000040%20x10%3A%20ffff0000d0d64050%20x9%20%3A%20ffff0000d0d64048%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20x8%20%3A%20ffff000006433b78%20x7%20%3A%200000000000000000%20x6%20%3A%20000002a5fe056003%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20x5%20%3A%2000ffffffffffffff%20x4%20%3A%20ffff0000d1b6c210%20x3%20%3A%200000000000000000%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20x2%20%3A%200000000000000000%20x1%20%3A%20ffff0000d02b6740%20x0%20%3A%200000000000000000%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20Call%20trace%3A%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20%20dma_fence_signal%2B0x58%2F0x64%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20%20gckOS_UserSignal%2B0x7c%2F0xb0%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20%20gckEVENT_Notify%2B0x21c%2F0x410%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20%20gckHARDWARE_Notify%2B0x68%2F0xc8%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20%20gckKERNEL_Notify%2B0x20%2F0x2c%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20%20threadRoutine%2B0x1c%2F0x78%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20%20kthread%2B0x110%2F0x114%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20%20ret_from_fork%2B0x10%2F0x20%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20Code%3A%202a1303e0%20a94153f3%20a8c27bfd%20d50323bf%20(d65f03c0)%20%20%0A%23%23%20imx8mp-lpddr4-evk%20kernel%3A%20---%5B%20end%20trace%200000000000000000%20%5D---%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%80%8Cdma_fence_signal%2B0x58%2F0x64%E3%80%8D%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%80%8Cdma_fence_signal%E3%80%8D%E9%96%A2%E6%95%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%810x58%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E5%91%BD%E4%BB%A4%E3%81%AF%E3%80%8Cret%E3%80%8D%E5%91%BD%E4%BB%A4%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Efile%20path%3A%20imx8mp-xwayland%2Ftmp%2Fwork-shared%2Fimx8mp-lpddr4-evk%2Fkernel-source%2Fdrivers%2Fdma-buf%2Fdma-fence.c%0A%0Aint%20dma_fence_signal(struct%20dma_fence%20*fence)%0A%7B%0A%09unsigned%20long%20flags%3B%0A%09int%20ret%3B%0A%09bool%20tmp%3B%0A%0A%09if%20(!fence)%0A%09%09return%20-EINVAL%3B%0A%0A%09tmp%20%3D%20dma_fence_begin_signalling()%3B%0A%0A%09spin_lock_irqsave(fence-%26gt%3Block%2C%20flags)%3B%0A%09ret%20%3D%20dma_fence_signal_timestamp_locked(fence%2C%20ktime_get())%3B%0A%09spin_unlock_irqrestore(fence-%26gt%3Block%2C%20flags)%3B%0A%0A%09dma_fence_end_signalling(tmp)%3B%0A%0A%09return%20ret%3B%0A%7D%0AEXPORT_SYMBOL(dma_fence_signal)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23%23%20aarch64-linux-gnu-objdump%20-r%20-d%20vmlinux%20%7C%20grep%20-A%2030%20%5C%3CDMA_FENCE_SIGNAL%3E%3A%0Affff8000809bcfe8%20%3CDMA_FENCE_SIGNAL%3E%3A%0Affff8000809bcfe8%3A%09d503233f%20%09paciasp%0Affff8000809bcfec%3A%09a9be7bfd%20%09stp%09x29%2C%20x30%2C%20%5Bsp%2C%20%23-32%5D!%0Affff8000809bcff0%3A%09910003fd%20%09mov%09x29%2C%20sp%0Affff8000809bcff4%3A%09a90153f3%20%09stp%09x19%2C%20x20%2C%20%5Bsp%2C%20%2316%5D%0Affff8000809bcff8%3A%09b4000260%20%09cbz%09x0%2C%20ffff8000809bd044%20%3CDMA_FENCE_SIGNAL%3E%0Affff8000809bcffc%3A%09aa0003f3%20%09mov%09x19%2C%20x0%0Affff8000809bd000%3A%09f9400000%20%09ldr%09x0%2C%20%5Bx0%5D%0Affff8000809bd004%3A%09942b4fed%20%09bl%09ffff800081490fb8%20%26lt%3B_raw_spin_lock_irqsave%26gt%3B%0Affff8000809bd008%3A%09aa0003f4%20%09mov%09x20%2C%20x0%0Affff8000809bd00c%3A%0997dd9d70%20%09bl%09ffff8000801245cc%20%3CKTIME_GET%3E%0Affff8000809bd010%3A%09aa0003e1%20%09mov%09x1%2C%20x0%0Affff8000809bd014%3A%09aa1303e0%20%09mov%09x0%2C%20x19%0Affff8000809bd018%3A%0997ffff6e%20%09bl%09ffff8000809bcdd0%20%3CDMA_FENCE_SIGNAL_TIMESTAMP_LOCKED%3E%0Affff8000809bd01c%3A%092a0003e2%20%09mov%09w2%2C%20w0%0Affff8000809bd020%3A%09aa1403e1%20%09mov%09x1%2C%20x20%0Affff8000809bd024%3A%09f9400260%20%09ldr%09x0%2C%20%5Bx19%5D%0Affff8000809bd028%3A%092a0203f3%20%09mov%09w19%2C%20w2%0Affff8000809bd02c%3A%09942b4eb5%20%09bl%09ffff800081490b00%20%26lt%3B_raw_spin_unlock_irqrestore%26gt%3B%0Affff8000809bd030%3A%092a1303e0%20%09mov%09w0%2C%20w19%0Affff8000809bd034%3A%09a94153f3%20%09ldp%09x19%2C%20x20%2C%20%5Bsp%2C%20%2316%5D%0Affff8000809bd038%3A%09a8c27bfd%20%09ldp%09x29%2C%20x30%2C%20%5Bsp%5D%2C%20%2332%0Affff8000809bd03c%3A%09d50323bf%20%09autiasp%0Affff8000809bd040%3A%09d65f03c0%20%09ret%0Affff8000809bd044%3A%09128002b3%20%09mov%09w19%2C%20%230xffffffea%20%20%20%20%20%20%20%20%20%20%20%20%09%2F%2F%20%23-22%0Affff8000809bd048%3A%0917fffffa%20%09b%09ffff8000809bd030%20%3CDMA_FENCE_SIGNAL%3E%3C%2FDMA_FENCE_SIGNAL%3E%3C%2FDMA_FENCE_SIGNAL_TIMESTAMP_LOCKED%3E%3C%2FKTIME_GET%3E%3C%2FDMA_FENCE_SIGNAL%3E%3C%2FDMA_FENCE_SIGNAL%3E%3C%2FDMA_FENCE_SIGNAL%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%81%AA%E3%81%9C%E3%80%8Cret%E3%80%8D%E5%91%BD%E4%BB%A4%E3%81%8C%E5%95%8F%E9%A1%8C%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E8%89%AF%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%93%E3%82%8C%E3%81%AF%E3%81%BE%E3%82%8C%E3%81%AB%E8%B5%B7%E3%81%93%E3%82%8B%E7%8F%BE%E8%B1%A1%E3%81%A7%E3%81%99%E3%80%82%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%A1%8C%E5%8B%95%E3%81%8C%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%97%E3%81%9F%E3%81%AE%E3%81%8B%E3%80%81%E3%81%BE%E3%81%A0%E5%88%86%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E5%86%8D%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2364422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2365848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20galcore_deamon%20Undefined%20instruction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2365848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255264%22%20target%3D%22_blank%22%3E%40James33%E3%81%95%E3%82%93%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%A8%99%E6%BA%96%E3%81%AELinux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82PREEMPT%20Linux%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2365905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20galcore_deamon%20Undefined%20instruction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2365905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eyocto%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AFscarthgap6.6.23%E3%81%A7%E3%81%99%E3%80%82linux-imx_6.6.bb%20%E3%81%AB%E3%81%AF%E4%B8%80%E5%88%87%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%82%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%97%E3%80%81galcore%E9%96%A2%E9%80%A3%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%82%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AEdts%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A0%E3%81%91%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E6%A8%99%E6%BA%96%E3%81%AELinux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E4%BB%96%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%82%E3%82%8A%E3%80%81dma_fence_signal%E3%81%AF%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%E3%81%AE1%E3%81%A4%E3%81%AB%E3%81%99%E3%81%8E%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%23%23%20zcat%20%2Fproc%2Fconfig.gz%20%7C%20grep%20PREEMPT%3CBR%20%2F%3E%20CONFIG_PREEMPT_BUILD%3Dy%3CBR%20%2F%3E%20%23%20CONFIG_PREEMPT_NONE%20%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%23%20CONFIG_PREEMPT_VOLUNTARY%20%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3ECONFIG_PREEMPT%3Dy%3CBR%20%2F%3E%20CONFIG_PREEMPT_COUNT%3Dy%3CBR%20%2F%3E%20CONFIG_PREEMPTION%3Dy%3CBR%20%2F%3E%20%23%20CONFIG_PREEMPT_DYNAMIC%20%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3ECONFIG_PREEMPT_RCU%3Dy%3CBR%20%2F%3E%20CONFIG_HAVE_PREEMPT_DYNAMIC%3Dy%3CBR%20%2F%3E%20CONFIG_HAVE_PREEMPT_DYNAMIC_KEY%3Dy%3CBR%20%2F%3E%20CONFIG_PREEMPT_NOTIFIERS%3Dy%3CBR%20%2F%3E%20%23%20CONFIG_DEBUG_PREEMPT%20%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-BODY%3E
