IMX8MP: Set up port forwarding
已解决
跳至解决方案
3,198 次查看
deepika_t
Hi All,
I am working on i.IMX8MP EVK Board running 5.4 Yocto kernel
As it has 2 Ethernet ports,
port 1 (eth0) Connected to my Ubuntu Machine
port 2(eth1)  Connected to IP Camera
I need to forward the packets received from Camera to my PC, so that I can view the IP camera from my machine.
Please suggest how to do so.
Deepika
1 解答
3,133 次查看
Zhiming_Liu
3 回复数
3,170 次查看
deepika_t
Thanks for the reply
Can you please let me know the commands required to do port forwarding.
Is it possible to use Iptables to do so?
Deepika
3,134 次查看
Zhiming_Liu
3,180 次查看
Zhiming_Liu
Did you try to use ffmpeg/gstreamer?
