IMX8MP MIPI-CSI2 Problems in custom camera
25,245 次查看
v_parri
Hi, my name is Victor and I'm in a project where we're trying to send image from a custom 4-lane camera to the IMX8MP (in a imx8mp-evk board) using the MIPI-CSI2 interface but I'm stuck trying to make it work.
I want to modify the ov5640 config and drivers but I'm not sure how many things I have to change. I'm ony interested in make it work sending image, the I2C is not needed at this moment and the camera is conected to the MIPI_CSI_0.
1) Is it enough if I modify the device tree configuration? which parameters do I have to modify? This is the configuration that I'm using:
imx8mp.dtsi:
mipi_csi_0: csi@32e40000 {
compatible = "fsl,imx8mp-mipi-csi", "fsl,imx8mn-mipi-csi";
reg = <0x32e40000 0x10000>;
interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
clock-frequency = <500000000>;
clocks = <&clk IMX8MP_CLK_MEDIA_CAM1_PIX>,
<&clk IMX8MP_CLK_MEDIA_AXI>,
<&clk IMX8MP_CLK_MEDIA_APB>;
clock-names = "mipi_clk", "disp_axi", "disp_apb";
assigned-clocks = <&clk IMX8MP_CLK_MEDIA_CAM1_PIX>;
assigned-clock-parents = <&clk IMX8MP_SYS_PLL2_1000M>;
assigned-clock-rates = <500000000>;
bus-width = <4>;
csi-gpr = <&mediamix_gasket0>;
gpr = <&mediamix_blk_ctl>;
no-reset-control;
power-domains = <&mipi_phy1_pd>;
status = "disabled";
imx8mp-evk.dts:
&mipi_csi_0 {
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
port@0 {
reg = <0>;
mipi_csi0_ep: endpoint {
remote-endpoint = <&ov5640_mipi_0_ep>;
data-lanes = <4>;
2) Do I have to modify the ov5640 driver too? I've located this driver: ov5640_mipi_v2.c but not sure about it
Just modifying the device tree if I try to build a pipe with gstreamer to read from video0 I'm getting this error:
gst-launch-1.0 -v v4l2src ! "video/x-bayer,format=bggr,width=640,height=480,framerate=30/1" ! bayer2rgb ! videoconvert ! autovideosink sync=false
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Device '/dev/video0' is not a capture device.Additional debug info:
../../../git/sys/v4l2/v4l2_calls.c(677): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Capabilities: 0x4204000
Setting pipeline to NULL ...
Freeing pipeline ...
Also the configuration read from v412-ctl tool is:
v4l2-ctl --list-devices
mxc-isi-m2m (platform:32e00000.isi:m2m_devic):
/dev/video0
v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture Multiplanar
[0]: 'RGBP' (16-bit RGB 5-6-5)
[1]: 'RGB3' (24-bit RGB 8-8-8)
[2]: 'BGR3' (24-bit BGR 8-8-8)
[3]: 'YUYV' (YUYV 4:2:2)
[4]: 'YUV4' (32-bit A/XYUV 8-8-8-8)
[5]: 'NV12' (Y/CbCr 4:2:0)
[6]: 'YM24' (Planar YUV 4:4:4 (N-C))
[7]: 'XR24' (32-bit BGRX 8-8-8-8)
[8]: 'AR24' (32-bit BGRA 8-8-8-8)
Please any help will be appreciated
25 回复数
17,303 次查看
joanxie
which dts file do you use? did you try to use imx8mp-evk-basler-ov5640.dtb?
2,792 次查看
Matt_S
I just used the evk dts as a base.  Should I use the Hassler one to get the camera working?
2,756 次查看
joanxie
I just got my imx8mp board, firstly, pls tell me what bsp version you use? let me reproduce this
2,237 次查看
Matt_S
Did you get any where with this?   It is important to get the capture device functioning.
2,730 次查看
v_parri
Hi, the BSP we're curently using is the 5.4.47.
Any help will be appreciated,
%3CLINGO-SUB%20id%3D%22lingo-sub-1234225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%AE%9A%E5%88%B6%E7%9B%B8%E6%9C%BA%E4%B8%AD%E7%9A%84%20IMX8MP%20MIPI-CSI2%20%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1234225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E5%8F%AB%20Victor%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E5%8F%82%E4%B8%8E%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20MIPI-CSI2%20%E6%8E%A5%E5%8F%A3%E5%B0%86%E5%9B%BE%E5%83%8F%E4%BB%8E%E8%87%AA%E5%AE%9A%E4%B9%89%204%20%E8%BD%A6%E9%81%93%E6%91%84%E5%83%8F%E6%9C%BA%E5%8F%91%E9%80%81%E5%88%B0%20IMX8MP%EF%BC%88%E5%9C%A8%20imx8mp-evk%20%E6%9D%BF%E4%B8%AD%EF%BC%89%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%80%E7%9B%B4%E6%97%A0%E6%B3%95%E8%AE%A9%E5%AE%83%E5%8F%91%E6%8C%A5%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E4%BF%AE%E6%94%B9%20ov5640%20%E7%9A%84%E9%85%8D%E7%BD%AE%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%9C%89%E5%A4%9A%E5%B0%91%E5%9C%B0%E6%96%B9%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E3%80%82%E6%88%91%E5%8F%AA%E6%83%B3%E8%AE%A9%E5%AE%83%E8%83%BD%E5%8F%91%E9%80%81%E5%9B%BE%E5%83%8F%EF%BC%8C%E7%9B%AE%E5%89%8D%E8%BF%98%E4%B8%8D%E9%9C%80%E8%A6%81%20I2C%EF%BC%8C%E7%9B%B8%E6%9C%BA%E5%B7%B2%E8%BF%9E%E6%8E%A5%E5%88%B0%20MIPI_CSI_0%E3%80%82%3C%2FP%3E%3CP%3E1)%20%E4%BF%AE%E6%94%B9%E8%AE%BE%E5%A4%87%E6%A0%91%E9%85%8D%E7%BD%AE%E6%98%AF%E5%90%A6%E8%B6%B3%E5%A4%9F%EF%BC%9F%E6%88%91%E5%BF%85%E9%A1%BB%E4%BF%AE%E6%94%B9%E5%93%AA%E4%BA%9B%E5%8F%82%E6%95%B0%EF%BC%9F%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3Eimx8mp.dtsi%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3Emipi_csi_0%EF%BC%9Acsi%20%4032e40000%20%7B%3CBR%20%2F%3E%20%E5%85%BC%E5%AE%B9%20%3D%20%22%20fsl%EF%BC%8Cimx8mp-mipi-csi%20%22%EF%BC%8C%22%20fsl%EF%BC%8Cimx8mn-mipi-csi%3CBR%20%2F%3E%20%22%EF%BC%9Breg%20%3D%26lt%3B0x32e40000%200x10000%26gt%3B%20%EF%BC%9B%E4%B8%AD%E6%96%AD%3CBR%20%2F%3E%20%3D%3CGIC_SPI%2017%3D%22%22%20irq_type_level_high%3D%22%22%3E%20%EF%BC%9B%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%3CBR%20%2F%3E%26lt%3B500000000%26gt%3B%26lt%3B500000000%26gt%3B%20%3CBR%20%2F%3E%26lt%3B4%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3D%20%26lt%3B%20%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E500000000%20%26gt%3B%3B%3CBR%20%2F%3E%20%E6%97%B6%E9%92%9F%20%3D%20%26lt%3B%20%26amp%3B%20clk%20IMX8MP_CLK_CLK_MEDIA_CAM1_PIX%20%26gt%3B%2C%20%26lt%3B%20%26amp%3B%20clk%20imx8MP_CLK_CLK_MEDIA_AXI%20%26gt%3B%EF%BC%8C%26lt%3B%20%26amp%3B%20clk%20IMX8MP_CLK_CLK_MEDIA_APB%20%26gt%3B%EF%BC%9B%E6%97%B6%E9%92%9F%E5%90%8D%E7%A7%B0%20%3D%20%22%20mipi_clk%20%22%2C%20%22%20disp_axi%20%22%2C%20%22%20disp_apb%20%22%3B%20%E5%88%86%E9%85%8D%20%E7%9A%84%E6%97%B6%E9%92%9F%20%3D%20%26lt%3B%20%26amp%3B%20clk%20imx8MP_CLK_CLK_CLK_CLK_CAM1_PIX%20%26gt%3B%3B%20%E5%88%86%E9%85%8D%E7%9A%84%E6%97%B6%E9%92%9F%E7%88%B6%E6%AF%8D%20%3D%20%26lt%3B%20%26amp%3B%20clk%20IMX8MP_SYS_PLL2_1000M%20%26gt%3B%3B%20%E5%88%86%E9%85%8D%E7%9A%84%E6%97%B6%E9%92%9F%20-rates%20%3D%20%EF%BC%9B%20%E6%80%BB%E7%BA%BF%E5%AE%BD%E5%BA%A6%20%3D%20%EF%BC%9Bc%20si-gpr%20%3D%20%26lt%3B%20%26amp%3B%20mediamix_gasket0%20%26gt%3B%EF%BC%9Bgpr%20%3D%20%26lt%3B%20%26amp%3B%20mediamix_blk_ctl%20%26gt%3B%EF%BC%9B%E6%97%A0%E9%87%8D%E7%BD%AE%E6%8E%A7%E5%88%B6%EF%BC%9B%E5%8A%9F%E7%8E%87%E5%9F%9F%20%3D%20%26lt%3B%20%26amp%3B%20mipi_phy1_pd%20%26gt%3B%3B%20%E7%8A%B6%E6%80%81%20%3D%2045%E5%B7%B2%E7%A6%81%E7%94%A8%20%22%3B%7D%3B%3C%2FGIC_SPI%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eimx8mp-evk.dts%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%26amp%3Bmipi_csi_0%20%7B%3CBR%20%2F%3E%23address-cells%20%3D%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%23size-cells%20%3D%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3Estatus%20%3D%22okay%22%20%EF%BC%9B%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3Eport%400%20%7B%3CBR%20%2F%3Ereg%20%3D%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3Emipi_csi0_ep%EF%BC%9Aendpoint%20%7B%3CBR%20%2F%3Eremote-endpoint%20%3D%26lt%3B%26amp%3B%20ov5640_mipi_0_ep%26gt%3B%3B%3CBR%20%2F%3Edata-lanes%20%3D%26lt%3B4%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%EF%BC%9B%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E2)%20%E6%88%91%E8%BF%98%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%20ov5640%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%90%97%EF%BC%9F%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9Aov5640_mipi_v2.c%E4%BD%86%E4%B8%8D%E7%A1%AE%E5%AE%9A%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20gstreamer%20%E6%9E%84%E5%BB%BA%E4%B8%80%E4%B8%AA%E7%AE%A1%E9%81%93%E6%9D%A5%E8%AF%BB%E5%8F%96%20video0%EF%BC%8C%E5%8F%AA%E9%9C%80%E4%BF%AE%E6%94%B9%E8%AE%BE%E5%A4%87%E6%A0%91%E5%B0%B1%E4%BC%9A%E9%81%87%E5%88%B0%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3Egst-launch-1.0-v%20v4l2src%20%EF%BC%81%22video%2Fx-bayer%2Cformat%3Dbggr%2Cwidth%3D640%2Cheight%3D480%2Cframerate%3D30%2F1%22%20%EF%BC%81bayer2rgb%20%EF%BC%81%E8%A7%86%E9%A2%91%E8%BD%AC%E6%8D%A2%20%EF%BC%81autovideosink%20sync%3Dfalse%3CBR%20%2F%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9A%82%E5%81%9C%20...%3CBR%20%2F%3EERROR%EF%BC%9A%E7%AE%A1%E9%81%93%E4%B8%8D%E6%83%B3%E6%9A%82%E5%81%9C%E3%80%82%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9D%A5%E8%87%AA%E5%85%83%E7%B4%A0%20%2FgstPipeline%3A%20pipeline0%2Fgstv4l2src%3A%20v4l2src0%EF%BC%9A%E8%AE%BE%E5%A4%87%20%E2%80%9C%2Fdev%2Fvideo0%E2%80%9D%20%E4%B8%8D%E6%98%AF%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%E3%80%82%E5%85%B6%E4%BB%96%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%EF%BC%9A..%2F...%2F...%20%3CBR%20%2F%3E%2Fgit%2Fsys%2Fv4l2%2Fv4l2_calls.c%20(677)%EF%BC%9Agst_v4l2_open%20()%3A%20%2FgstPipeline%3A%20pipeline0%2Fgstv4l2src%3A%20v4l2src0%EF%BC%9A%E5%8A%9F%E8%83%BD%EF%BC%9A0x4204000%20%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%E7%A9%BA...%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E9%87%8A%E6%94%BE%E7%AE%A1%E9%81%93...%3C%2FP%3E%3CP%3E%E4%BB%8E%20v412-ctl%20%E5%B7%A5%E5%85%B7%E8%AF%BB%E5%8F%96%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B9%9F%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%9A%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3Ev4l2-ctl--%3CBR%20%2F%3E%20list-devices%20mxc-isi-m2m%EF%BC%88%E5%B9%B3%E5%8F%B0%EF%BC%9A32e00000.isi%3A%20m2m_devic%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%2Fdev%2Fvideo0%3C%2FP%3E%3CBR%20%2F%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3Ev4l2-ctl--list-formats-ext%20ioctl%EF%BC%9AVIDIOC_ENUM_FMT%20%E7%B1%BB%E5%9E%8B%3CBR%20%2F%3E%EF%BC%9A%E5%A4%9A%E5%B9%B3%E9%9D%A2%E8%A7%86%E9%A2%91%E6%8D%95%E8%8E%B7%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%5B0%5D%3A%20'RGBP'%20(16%20%E4%BD%8D%20RGB%205-6-5)%3CBR%20%2F%3E%5B1%5D%3A%20'RGB3'%20(24%20%E4%BD%8D%20RGB%208-8-8)%3CBR%20%2F%3E%5B2%5D%3A%20'BGR3'%20(24%20%E4%BD%8D%20BGR%208-8-8)%3CBR%20%2F%3E%5B3%5D%3A%20'YUYV'%20(YUYV%204%3A2%3A2)%3CBR%20%2F%3E%5B4%5D%3A%20'YUV4'%20(32%20%E4%BD%8D%20A%2FXYUV%208-8-8)%3CBR%20%2F%3E%5B5%5D%EF%BC%9ANV12'%EF%BC%88Y%2FCbCr%204%3A2%3A0%EF%BC%89%3CBR%20%2F%3E%5B6%5D%EF%BC%9A'YM24'%EF%BC%88%E5%B9%B3%E9%9D%A2%20YUV%204%3A4%3A4%EF%BC%88N-C%EF%BC%89%EF%BC%89%3CBR%20%2F%3E%5B7%5D%EF%BC%9A'XR24'%EF%BC%8832%20%E4%BD%8D%20BGRX%208-8-8%EF%BC%89%3CBR%20%2F%3E%5B8%5D%EF%BC%9A'AR24'%EF%BC%8832%20%E4%BD%8D%20BGRA%208-8-8%EF%BC%89%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%EF%BC%8C%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2290315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2290315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E7%BB%B4%E5%85%8B%E5%A4%9A%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%20i.mx8MP%20%E8%80%8C%E8%A8%80%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%87%AA%E5%AE%9A%E4%B9%89%20CSI-2%20%E6%91%84%E5%83%8F%E6%9C%BA%E6%97%B6%EF%BC%8C%3CSTRONG%3E%E4%BB%85%E6%9B%B4%E6%94%B9%E8%AE%BE%E5%A4%87%E6%A0%91%E6%98%AF%E4%B8%8D%E5%A4%9F%3C%2FSTRONG%3E%E7%9A%84%E3%80%82CSI%20%E5%8C%BA%E5%9D%97%E5%B0%86%E8%BF%9B%E8%A1%8C%E6%9E%9A%E4%B8%BE%EF%BC%8C%E4%BD%86%E6%98%AF%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E6%AD%A3%E7%A1%AE%E7%BB%91%E5%AE%9A%E7%9A%84%20%3CSTRONG%3EV4L2%20%E5%AD%90%E8%AE%BE%E5%A4%87%EF%BC%88%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%89%3C%2FSTRONG%3E%E5%92%8C%E5%AA%92%E4%BD%93%E5%9B%BE%EF%BC%8C%2Fdev%2Fvideo0%20%E6%9C%80%E7%BB%88%E4%BC%9A%E6%88%90%E4%B8%BA%20ISI%20m2m%20%E8%8A%82%E7%82%B9%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%E2%80%94%E2%80%94%E8%BF%99%E8%A7%A3%E9%87%8A%E4%BA%86%E4%BD%A0%E7%9C%8B%E5%88%B0%E7%9A%84%20GStreamer%20%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E5%8D%B3%E4%BD%BF%E6%9C%80%E5%88%9D%E4%B8%8D%E9%9C%80%E8%A6%81%20I%C2%B2C%20%E6%8E%A7%E5%88%B6%EF%BC%8C%E4%BC%A0%E6%84%9F%E5%99%A8%E9%A9%B1%E5%8A%A8%E5%99%A8%EF%BC%88%E6%88%96%E5%9F%BA%E4%BA%8E%20ov5640%20%E7%9A%84%E6%9C%80%E5%B0%8F%E7%9F%AD%E6%88%AA%E7%BA%BF%EF%BC%89%E4%BB%8D%E7%84%B6%E9%9C%80%E8%A6%81%E9%80%9A%E5%91%8A%E6%A0%BC%E5%BC%8F%E3%80%81%E9%80%9A%E9%81%93%E3%80%81%E6%97%B6%E9%92%9F%E5%B9%B6%E8%BF%9E%E6%8E%A5%20CSI%20%E2%86%92%20ISI%20%E7%AE%A1%E9%81%93%E3%80%82%E4%BB%85%E4%BF%AE%E6%94%B9%20ov5640%20DT%20%E8%80%8C%E4%B8%8D%E6%9B%B4%E6%94%B9%E7%9B%B8%E5%BA%94%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%8D%E4%BC%9A%E6%9A%B4%E9%9C%B2%E5%85%B7%E6%9C%89%E6%8D%95%E8%8E%B7%E5%8A%9F%E8%83%BD%E7%9A%84%E8%A7%86%E9%A2%91%E8%8A%82%E7%82%B9%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%AE%9E%E8%B7%B5%E4%B8%AD%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E4%B8%8E%20CSI-2%20%E8%BE%93%E5%87%BA%EF%BC%88%E8%BD%A6%E9%81%93%E6%95%B0%E3%80%81%E6%A0%BC%E5%BC%8F%E3%80%81%E5%AE%9A%E6%97%B6%EF%BC%89%E7%9B%B8%E5%8C%B9%E9%85%8D%E7%9A%84%E4%BC%A0%E6%84%9F%E5%99%A8%2F%E5%AD%90%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E4%BC%A0%E6%84%9F%E5%99%A8%20%E2%86%92%20MIPI-CSI%20%E2%86%92%20ISI%20%E4%B9%8B%E9%97%B4%E7%9A%84%E6%AD%A3%E7%A1%AE%E5%AA%92%E4%BD%93%E9%93%BE%E6%8E%A5%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%9C%A8%E4%BD%BF%E7%94%A8%20v4l2-ctl%20%E6%88%96%20GStreamer%20%E4%B9%8B%E5%89%8D%EF%BC%8C%E9%80%9A%E8%BF%87%20media-ctl%20-p%20%E8%BF%9B%E8%A1%8C%E9%AA%8C%E8%AF%81%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E4%B8%80%E4%BA%9B%E4%B8%8A%E6%B8%B8%E5%8F%82%E8%80%83%E8%B5%84%E6%96%99%E5%8F%AF%E8%83%BD%E6%9C%89%E5%8A%A9%E4%BA%8E%E5%8D%8F%E8%B0%83%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6%E5%B9%B3%E5%8F%B0%E4%B8%8A%E6%B5%8B%E8%AF%95%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2BDT%3C%2FP%3E%3CP%3E%3CSTRONG%3ELinux%20%E7%9B%B8%E6%9C%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fweb.git.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Fnext%2Flinux-next.git%2Fcommit%2F%3Fid%3Dfa9e6df636fb8b3b27570f38c53640c9e2b02f79%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fweb.git.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Fnext%2Flinux-next.git%2Fcommit%2F%3Fid%3Dfa9e6df636fb8b3b2...%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fpatchew.org%2Flinux%2F20251216065956.13604-1-himanshu.bhavani%40siliconsignals.io%2F20251216065956.13604-3-himanshu.bhavani%40siliconsignals.io%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fpatchew.org%2Flinux%2F20251216065956.13604-1-himanshu.bhavani%40siliconsignals.io%2F20251216065956.1...%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fweb.git.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Fnext%2Flinux-next.git%2Fcommit%2F%3Fid%3D5bd6b8c1bb2d49d5ff15c7c47d6b33d2d38785f0%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fweb.git.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Fnext%2Flinux-next.git%2Fcommit%2F%3Fid%3D5bd6b8c1bb2d49d5f...%3C%2FA%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSTRONG%3EZephyr%20%E6%91%84%E5%83%8F%E6%9C%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fcommit%2Fc784481ca039ccd606a192ee07bc83f6b0117e59%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fcommit%2Fc784481ca039ccd606a192ee07bc83f6b0117e59%3C%2FA%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fsiliconsignals.io%2F%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESilicon%20Signals%3C%2FA%3E%E6%8F%90%E4%BE%9B%E7%9A%84%E7%9B%B8%E6%9C%BA%E5%8D%87%E7%BA%A7%E6%8C%87%E5%8D%97%3C%2FP%3E%3COL%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fsiliconsignals.io%2Fblog%2Fv4l2-camera-stack-step-by-step-guide-for-custom-devices%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fsiliconsignals.io%2Fblog%2Fv4l2-camera-stack-step-by-step-guide-for-custom-devices%2F%3C%2FA%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E6%82%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1304882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1304882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8Cv_parri%E3%80%81%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E6%8A%8A%E5%9B%9B%E8%BD%A6%E9%81%93%E5%8F%98%E4%B8%BA%E5%9B%9B%E8%BD%A6%E9%81%93%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%82%A8%E5%AF%B9%20imx8mp.dtsi%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%20CSI%20%E9%83%A8%E5%88%86%E5%81%9A%E4%BA%86%E5%93%AA%E4%BA%9B%E4%BF%AE%E6%94%B9%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8CMC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1291972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1291972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%8F%96%E5%BE%97%E4%BA%86%E4%B8%80%E4%BA%9B%E8%BF%9B%E5%B1%95%EF%BC%8C%E4%BD%86%E6%88%91%E6%B2%A1%E6%9C%89%E8%8E%B7%E5%BE%97%20%2Fdev%2Fvideo%EF%BC%88%E7%94%B1%20imx8-isi-m2m.c%20%E5%88%9B%E5%BB%BA%EF%BC%89%E3%80%81%E7%94%9A%E8%87%B3%E5%9C%A8%E8%A2%AB%E6%9F%A5%E8%AF%A2%E6%97%B6%E6%9C%89%E6%8D%95%E8%8E%B7%E8%83%BD%E5%8A%9B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%80%8C%E4%B8%94%E6%88%91%E4%B9%9F%E6%B2%A1%E6%9C%89%20media0%20%E8%AE%BE%E5%A4%87%E3%80%82%E6%88%91%E5%BC%80%E5%A7%8B%E8%A7%89%E5%BE%97%E7%9B%B8%E6%9C%BA%E5%9D%8F%E4%BA%86%EF%BC%81%20%20%20%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%87%E7%9A%84%E4%BB%BB%E4%BD%95%20CONFIG%20%E9%83%BD%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E6%95%88%E6%9E%9C%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1291756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1291756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E5%B4%A9%E6%BA%83%E7%9A%84%E4%B8%8D%E6%98%AF%20probe%EF%BC%8C%E8%80%8C%E6%98%AF%20mxc_isi_m2m_g_fmt_vid_caps%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1291755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1291755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%BF%98%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%20NULL%20%E6%8C%87%E9%92%88%E9%97%AE%E9%A2%98%E3%80%82%E5%9C%A8%3CSPAN%3Ev4l2_subdev_pad_ops%20%3C%2FSPAN%3E%E7%9A%84%E5%87%BD%E6%95%B0%3CSPAN%3E.set_fmt%20%3C%2FSPAN%3E%E4%B8%AD%EF%BC%8Cfmt%20%E6%8C%87%E9%92%88%E8%A2%AB%E8%AE%BE%E7%BD%AE%E4%B8%BA%20NULL%E3%80%82%20%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%8F%91%E7%8E%B0%E8%AF%A5%E5%8A%9F%E8%83%BD%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%E4%BD%86%E4%B8%8E%E6%AD%A4%E5%90%8C%E6%97%B6%EF%BC%8C%E6%88%91%E6%94%B9%E4%BA%86%E5%BE%88%E5%A4%9A%E6%AC%A1%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%86%E8%BF%99%E6%AD%A3%E6%98%AF%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6%E7%9A%84%E9%A2%86%E5%9F%9F%E3%80%82%E6%88%91%E7%9A%84%E6%84%9F%E8%A7%89%E6%98%AF%EF%BC%8C%E7%84%8A%E7%9B%98%E6%98%AF%E4%BB%A5%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%96%B9%E5%BC%8F%E8%BF%9E%E6%8E%A5%E5%9C%A8%E4%B8%80%E8%B5%B7%E7%9A%84%EF%BC%8C%E4%BD%86%E5%B8%A7%E6%A0%BC%E5%BC%8F%E3%80%81%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E5%92%8C%20fps%20%E7%9A%84%E5%8D%8F%E5%95%86%E5%B9%B6%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%88%97%E5%87%BA%E5%8F%AF%E7%94%A8%E7%9A%84%E6%A0%BC%E5%BC%8F%EF%BC%8C%E4%BD%86%E7%B1%BB%E5%9E%8B%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%E5%AE%83%E6%80%BB%E6%98%AF%E6%98%BE%E7%A4%BA%20GRAY%EF%BC%888%20%E4%BD%8D%E7%81%B0%E5%BA%A6%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3Ev4l2-ctl--%E8%AE%BE%E5%A4%87%20%2Fdev%2Fvideo0--list-formats-ext%20%3CBR%20%2F%3E%20ioctl%EF%BC%9AVIDIOC_ENUM_FMT%20%3CBR%20%2F%3E%20%E7%B1%BB%E5%9E%8B%EF%BC%9A%E5%A4%9A%E5%B9%B3%E9%9D%A2%E8%A7%86%E9%A2%91%E6%8D%95%E8%8E%B7%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%5B0%5D%EF%BC%9A%E2%80%9C%E7%81%B0%E8%89%B2%E2%80%9D%EF%BC%888%20%E4%BD%8D%E7%81%B0%E5%BA%A6%EF%BC%89%E5%B0%BA%E5%AF%B8%EF%BC%9A%E7%A6%BB%E6%95%A3%20768x576%20%E9%97%B4%E9%9A%94%EF%BC%9A%E7%A6%BB%E6%95%A3%200.040s%EF%BC%8825.000%20fps%EF%BC%89%E5%B0%BA%E5%AF%B8%EF%BC%9A%E7%A6%BB%E6%95%A3%20640x480%20%E9%97%B4%E9%9A%94%EF%BC%9A%E7%A6%BB%E6%95%A3%200.033s%EF%BC%8830.000%20fps%EF%BC%89%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1291753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1291753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B8%AE%E4%BA%86%E5%A4%A7%E5%BF%99%EF%BC%8C%E8%B0%A2%E8%B0%A2%E3%80%82%20%20%20%E6%88%91%E7%9C%8B%E5%88%B0%E8%BF%87%E5%9C%A8%E8%84%9A%E6%9C%AC%E4%B8%AD%E4%BD%BF%E7%94%A8%E5%AA%92%E4%BD%93%E6%9D%A5%E8%AE%BE%E7%BD%AE%E5%9C%B0%E5%BD%A2%EF%BC%8C%E4%BD%86%E9%82%A3%E6%98%AF%E5%9C%A8%E8%BE%83%E6%97%A7%E7%9A%84%E7%B3%BB%E7%BB%9F%E4%B8%8A%EF%BC%8C%E6%88%91%E7%8C%9C%E5%9C%A8%E8%BE%83%E6%96%B0%E7%9A%84%E5%86%85%E6%A0%B8%E4%B8%8A%E6%98%AF%E9%80%9A%E8%BF%87%20pad%20%E4%BB%A5%E7%BC%96%E7%A8%8B%E6%96%B9%E5%BC%8F%E5%AE%8C%E6%88%90%E7%9A%84%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%94%A8%E5%AE%83%E6%9D%A5%E5%B1%95%E7%A4%BA%E5%9C%B0%E5%BD%A2%E7%9A%84%E5%B0%8F%E6%8F%90%E7%A4%BA%EF%BC%8C%E5%A4%AA%E5%AE%8C%E7%BE%8E%E4%BA%86%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E5%9C%A8%20imx8-isi-m2m.c%20%E4%B8%AD%E5%87%BA%E7%8E%B0%E4%BA%86%20kennel%20%E7%A9%BA%E6%8C%87%E9%92%88%E5%8F%96%E6%B6%88%E5%BC%95%E7%94%A8%E7%8E%B0%E8%B1%A1%E7%84%B6%E5%90%8E%E8%BF%9B%E8%A1%8C%E6%8E%A2%E6%B5%8B%E3%80%82%20fmt%20%E6%88%90%E5%91%98%E4%B8%BA%E7%A9%BA%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%BF%99%E6%98%AF%E5%88%9B%E5%BB%BA%20%2Fdev%2Fvideo0%20%E7%9A%84%E8%AE%BE%E5%A4%87%E4%BD%A0%E7%9C%8B%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%BF%87%E8%BF%99%E4%B8%AA%E5%90%97%EF%BC%9F%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%EF%BC%8C%E6%AD%A3%E5%87%86%E5%A4%87%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%EF%BC%8C%E4%BD%86%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9F%A5%E9%81%93%E5%8E%9F%E5%9B%A0%EF%BC%8C%E9%82%A3%E5%B0%86%E4%BC%9A%E5%B8%AE%E4%B8%8A%E5%A4%A7%E5%BF%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1291728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1291728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E6%B7%BB%E5%8A%A0%E5%AA%92%E4%BD%93%E5%AE%9E%E4%BD%93%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ev4l2_i2c_subdev_init%3C%2FSPAN%3E%3CSPAN%3E(%26amp%3B%3C%2FSPAN%3E%3CSPAN%3E%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%8Ci2c_client%EF%BC%8C%26amp%3Bsensor_subdev_ops%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eflags%3C%2FSPAN%3E%3CSPAN%3E%7C%3D%20v4l2_subdev_fl_has_devnode%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Einternal_ops%3C%2FSPAN%3E%3CSPAN%3E%3D%26amp%3Bsensor_subdev_internal_ops%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E%E5%AE%9E%E4%BD%93%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E%E5%8A%9F%E8%83%BD%3C%2FSPAN%3E%3CSPAN%3E%3D%20media_ent_f_cam_sensor%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E%E5%AE%9E%E4%BD%93%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E%E6%93%8D%E4%BD%9C%3C%2FSPAN%3E%3CSPAN%3E%3D%26amp%3Bsensor_entity_ops%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E4%BC%A0%E6%84%9F%E5%99%A8%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%9E%AB%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%5D.%3C%2FSPAN%3E%3CSPAN%3E%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3CSPAN%3E%3D%20media_pad_fl_source%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E4%BF%9D%E7%95%99%3C%2FSPAN%3E%3CSPAN%3E%3D%20%3C%2FSPAN%3E%3CSPAN%3Emedia_entity_pads_init%3C%2FSPAN%3E%3CSPAN%3E(%26amp%3B%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%90%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E%E5%AE%9E%E4%BD%93%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%9E%AB%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20media-ctl%20%E5%B7%A5%E5%85%B7%E6%89%93%E5%8D%B0%E6%8B%93%E6%89%91%E5%9B%BE%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CPRE%20translate%3D%22no%22%3Emedia-ctl%20--print-topology%0Amedia-ctl%20--print-dot%20%26gt%3B%20graph.dot%0Adot%20-Tpng%20graph.dot%20%26gt%3B%20graph.png%3C%2FPRE%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22graph.png%22%20style%3D%22width%3A%20497px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22graph.png%22%20style%3D%22width%3A%20497px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F146984iDF113688AE6E5541%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22graph.png%22%20alt%3D%22graph.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1291340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1291340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%89%E4%BB%80%E4%B9%88%E8%BF%9B%E5%B1%95%E5%90%97%EF%BC%9F%20%20%20%E8%AE%A9%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E5%BE%88%E9%87%8D%E8%A6%81%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1291336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1291336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%80%E4%B9%88%E6%98%AF%20%22%E5%AA%92%E4%BD%93%E5%AE%9E%E4%BD%93%22%EF%BC%8C%E5%A6%82%E4%BD%95%E6%B7%BB%E5%8A%A0%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9F%20%E5%BE%88%E9%AB%98%E5%85%B4%E7%9C%8B%E5%88%B0%E4%BD%A0%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E9%93%BE%E6%8E%A5%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E5%BE%88%E9%87%8D%E8%A6%81%EF%BC%8C%E8%BF%99%E4%BC%BC%E4%B9%8E%E6%98%AF%E5%BB%BA%E7%AB%8B%E8%AE%BE%E5%A4%87%E5%9C%B0%E5%BD%A2%E7%9A%84%E6%96%B9%E5%BC%8F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1278377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1278377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%88%87%E6%8D%A2%E5%9B%9E%3CSPAN%3E%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20imx8m%3C%2FSPAN%3E%3CU%3E%3CSTRONG%3E%20n%3C%2FSTRONG%3E%3C%2FU%3E%3CSPAN%3E%20-mipi-csi%EF%BC%88mx%20c-mipi-csi2-sam%EF%BC%89%E7%84%B6%E5%90%8E%E5%9C%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%E5%AA%92%E4%BD%93%E5%AE%9E%E4%BD%93%E3%80%82%E7%8E%B0%E5%9C%A8%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E4%B8%80%E4%B8%AA%20video0%20%E8%AE%BE%E5%A4%87%E4%BA%86%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Edmesg%20%7C%20grep%20mipi%0A%5B%20%20%20%201.888060%5D%20mxc-mipi-csi2-sam%2032e40000.csi%3A%2032e40000.csi%20supply%20mipi-phy%20not%20found%2C%20using%20dummy%20regulator%0A%5B%20%20%20%201.902159%5D%20mxc-mipi-csi2-sam%2032e40000.csi%3A%20lanes%3A%202%2C%20hs_settle%3A%2013%2C%20clk_settle%3A%202%2C%20wclk%3A%201%2C%20freq%3A%20500000000%0A%5B%20%20%20%202.862258%5D%20mx8-img-md%3A%20created%20link%20%5Bmxc-mipi-csi2.0%5D%20%3D%26gt%3B%20%5Bmxc_isi.0%5D%0A%5B%20%20%20%202.868710%5D%20mx8-img-md%3A%20created%20link%20%5Bs2d13p04%202-0037%5D%20%3D%26gt%3B%20%5Bmxc-mipi-csi2.0%5D%0Amoba%40moba-hmi%3A~%24%20dmesg%20%7C%20grep%20video0%0A%5B%20%20%20%202.842503%5D%20mx8-img-md%3A%20Registered%20mxc_isi.0.capture%20as%20%2Fdev%2Fvideo0%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E6%88%91%E7%8E%B0%E5%9C%A8%E7%A6%BB%E6%88%91%E7%9A%84%E7%9B%AE%E6%A0%87%E5%8F%88%E8%BF%91%E4%BA%86%E4%B8%80%E6%AD%A5%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277476%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277476%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%B9%9F%E4%BD%BF%E7%94%A8%205.4.70%20%E5%86%85%E6%A0%B8%E3%80%82%E4%BD%A0%E5%9C%A8%E5%93%AA%E9%87%8C%E6%89%BE%E5%88%B0%E5%8F%B8%E6%9C%BA%E7%9A%84%EF%BC%9F%E5%BD%93%E6%88%91%E6%90%9C%E7%B4%A2%20fsl%2Cimx8mp-mipi-csi%20%E6%95%B4%E4%BD%93%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AA%E5%9C%A8%20imx8mp.dtsi%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%89%BE%E5%88%B0%E4%BA%86%E6%9D%A1%E7%9B%AE%EF%BC%8C%E4%BD%86%E5%9C%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%83%A8%E5%88%86%E5%8D%B4%E6%89%BE%E4%B8%8D%E5%88%B0%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%205.4%20%E5%86%85%E6%A0%B8%EF%BC%8C%E5%85%B6%E4%B8%AD%E6%9C%89%E4%B8%80%E4%B8%AA%208MP%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E8%AF%A5%E5%A6%82%E4%BD%95%E5%B0%86%E8%BF%99%E4%BA%9B%E5%86%85%E5%AE%B9%E6%95%B4%E5%90%88%E5%9C%A8%E4%B8%80%E8%B5%B7%EF%BC%8C%E6%89%80%E4%BB%A5%E6%81%90%E6%80%95%E6%97%A0%E6%B3%95%E5%8F%91%E8%A1%A8%E6%84%8F%E8%A7%81%E3%80%82%20%E5%8F%AF%E8%83%BD%E7%BC%BA%E5%B0%91%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%8C%E4%BC%BC%E4%B9%8E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%86%E6%88%91%E5%B0%B1%E6%98%AF%E4%B8%8D%E7%9F%A5%E9%81%93%E3%80%82.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9A%84%E5%8E%9F%E7%82%B9%20imx8mp.dtsi%20%E4%B8%AD%EF%BC%8Cmipi_csi_0%20%E5%85%BC%E5%AE%B9%E5%AD%97%E7%AC%A6%E4%B8%B2%E4%B8%BA%3C%2FP%3E%3CDIV%3E%3CDIV%3E%E5%85%BC%E5%AE%B9%20%3D%22fsl%2Cimx8mp-mipi-csi%22%2C%22fsl%2Cimx8mn-mipi-csi%22%20%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%B2%A1%E6%9C%89%20imx8mp-mipi-csi%20%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E8%80%8C%E4%B8%94%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E4%BD%BF%E7%94%A8%20imx8m%20%3CU%3E%3CSTRONG%3En%3C%2FSTRONG%3E%3C%2FU%3E-mipi-csi%20%E6%88%91%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%B6%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%86%85%E6%A0%B8%E5%B4%A9%E6%BA%83%E3%80%82%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E6%94%B9%E7%94%A8%20imx8mm-mipi-csi%20%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%8C%82%E8%B5%B7%E7%8A%B6%E6%80%81%E4%B8%8E%E5%86%85%E6%A0%B8%E7%9A%84%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%E5%8D%95%E5%85%83%E6%9C%89%E5%85%B3%E3%80%82%E5%BD%93%E8%AE%BE%E5%A4%87%E4%B8%8D%E4%BD%BF%E7%94%A8%E6%97%B6%EF%BC%8C%E5%86%85%E6%A0%B8%E5%B0%86%E5%85%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%8C%82%E8%B5%B7%E6%A8%A1%E5%BC%8F%E4%BB%A5%E8%8A%82%E7%9C%81%E7%94%B5%E5%8A%9B%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E5%8F%AF%E8%83%BD%E5%9C%A8%20mipi_csi%20%E5%92%8C%20isp%20%E4%B9%8B%E9%97%B4%E7%BC%BA%E5%B0%91%E4%B8%80%E4%B8%AA%E9%93%BE%E6%8E%A5%EF%BC%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%9C%A8%20dtsi%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%8A%8A%E9%82%A3%E4%B8%AA%E8%AE%BE%E4%B8%BA%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%8C%E4%BD%86%E5%B0%B1%E6%88%91%E8%80%8C%E8%A8%80%EF%BC%8C%E6%88%91%E5%9C%A8%20imx8mp%20%E6%9D%BF%E4%B8%8A%EF%BC%8C%E6%89%80%E4%BB%A5%E6%98%AF%EF%BC%9Adsti%20%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%83%8F%E8%BF%99%E6%A0%B7%EF%BC%9A%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Emipi_csi_0%3A%3CA%20href%3D%22mailto%3Acsi%4032e40000%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ecsi%4032e40000%3C%2FA%3E%7B%3C%2FP%3E%3CP%3E%20%20%20%20%E5%85%BC%E5%AE%B9%20%3D%22FSL%2Cimx8mp-mipi-csi%22%2C%22FSL%2C%20imx8mm-mipi-csi%22%20%EF%BC%9B%3C%2FP%3E%3CP%3E...%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E7%9A%84%20dts%20%E6%96%87%E4%BB%B6%E5%B9%B6%E6%B2%A1%E6%9C%89%E6%94%B9%E5%8F%98%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E5%AE%83%E7%9A%84%20mipi_csi_0%20%E8%8A%82%E7%82%B9%E5%8F%AA%E6%98%AF%E5%B0%86%E5%85%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%90%AF%E7%94%A8%EF%BC%8C%E5%B9%B6%E8%AE%BE%E7%BD%AE%E4%BA%86%E4%B8%80%E4%B8%AA%E8%BF%9C%E7%A8%8B%20enpoint%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%A9%AC%E7%89%B9%EF%BC%8C%E4%BD%A0%E4%B8%BA%20mipi_csi_0%20%E4%BD%BF%E7%94%A8%E4%BA%86%E5%93%AA%E7%A7%8D%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E7%9B%AE%E5%89%8D%E4%BD%BF%E7%94%A8%20%2Fdriver%2Fmedia%2Fplatform%2Fmxc%2F%E6%8D%95%E8%8E%B7%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E7%9A%84%20mxc_mipi_csi%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%26amp%3Bmipi_csi_0%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%85%BC%E5%AE%B9%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E%22fsl%E3%80%81imx8mm-mipi-csi%22%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%8E%20dmesg%20%E4%B8%AD%E6%90%9C%E7%B4%A2%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E4%B8%AD%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%90%8D%E7%A7%B0%20%22mxc-mipi-csi2-sam%22%EF%BC%8C%E8%BF%9B%E5%85%A5%E8%AF%A5%E7%9B%AE%E5%BD%95%EF%BC%8C%E5%B9%B6%E6%8C%89%E7%85%A7%E7%A1%AC%E4%BB%B6%E5%9C%B0%E5%9D%80.csi%20%E9%93%BE%E6%8E%A5%EF%BC%8C%E5%9C%A8%E8%AF%A5%E7%9B%AE%E5%BD%95%E4%B8%8B%E6%98%AF%E7%94%B5%E6%BA%90%E7%9B%AE%E5%BD%95%EF%BC%8C%E5%85%B6%E4%B8%AD%E6%9C%89%E4%B8%80%E4%B8%AA%E7%8A%B6%E6%80%81%E3%80%82%20%20%20%E6%88%91%E6%83%B3%E8%BF%99%E5%B0%B1%E6%98%AF%E7%A1%AC%E4%BB%B6%E7%9A%84%E7%8A%B6%E5%86%B5%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E4%BA%86%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E7%97%95%E8%BF%B9%E3%80%82%20%E4%BD%86%E4%B8%8D%E7%A1%AE%E5%AE%9A%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E4%BB%80%E4%B9%88%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E4%B8%8D%E8%AE%B0%E5%BE%97%E5%9C%A8%E5%93%AA%E9%87%8C%E7%9C%8B%E5%88%B0%E5%AE%83%E8%AF%B4%E6%9A%82%E5%81%9C%E4%BA%86%EF%BC%8C%E5%8F%AF%E8%83%BD%E6%98%AF%E5%9C%A8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E7%9A%84%E6%9F%90%E4%B8%AA%E5%9C%B0%E6%96%B9%E3%80%82%E6%88%91%E4%BC%9A%E8%AF%95%E7%9D%80%E6%89%BE%E6%89%BE%E7%9A%84%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E8%AE%BE%E5%A4%87%E5%A4%84%E4%BA%8E%E6%9A%82%E5%81%9C%E7%8A%B6%E6%80%81%EF%BC%9F%E5%8F%AF%E4%BB%A5%E5%8A%A0%E8%A3%85%E5%8A%A8%E5%8A%9B%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E5%85%B6%E4%B8%AD%E4%B8%80%E6%9D%A1%20dmesg%20%E4%BF%A1%E6%81%AF%EF%BC%9A%20%3C%2FP%3E%3CP%3Emxc_mipi-csi%2032e40000.csi%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%2032e40000.csi%20%E7%94%B5%E6%BA%90%20mipi-phy%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%81%87%E8%B0%83%E8%8A%82%E5%99%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%8F%AA%E6%98%AF%E7%94%A8%20evk%20dts%20%E4%BD%9C%E4%B8%BA%E5%9F%BA%E7%A1%80%E3%80%82%20%E6%88%91%E5%BA%94%E8%AF%A5%E7%94%A8%E5%93%88%E6%96%AF%E5%8B%92%E7%9A%84%E9%82%A3%E4%B8%AA%E6%9D%A5%E8%AE%A9%E7%9B%B8%E6%9C%BA%E5%B7%A5%E4%BD%9C%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%B8%8D%EF%BC%8C%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E3%80%82%20%E4%BD%A0%E7%9F%A5%E9%81%93%E5%93%AA%E4%B8%AA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%88%9B%E5%BB%BA%E4%BA%86%20%2Fdev%2Fvideo%20%E8%AE%BE%E5%A4%87%E5%90%97%EF%BC%8C%E6%88%91%E6%9C%AC%E6%9D%A5%E6%83%B3%E4%BB%8E%E9%82%A3%E9%87%8C%E5%9B%9E%E8%BF%87%E5%A4%B4%E6%9D%A5%E7%9C%8B%E7%9C%8B%E5%AE%83%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%85%E4%BE%9B%E5%8F%82%E8%80%83%20dmesg%20%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%AD%A3%E5%B8%B8%EF%BC%8C%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%86%E6%98%AF%E8%AE%BE%E5%A4%87%E6%98%BE%E7%A4%BA%E4%B8%BA%E5%B7%B2%E6%8C%82%E8%B5%B7%EF%BC%8C%E6%89%80%E4%BB%A5%E4%B9%9F%E8%AE%B8%E5%8F%AF%E4%BB%A5%E5%9C%A8%20dts%20%E8%8A%82%E7%82%B9%E4%B8%8A%E6%B7%BB%E5%8A%A0%E7%94%B5%E6%BA%90%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E6%89%BE%E5%88%B0%E4%BA%86%20csi%20%E4%B8%8D%E5%88%9B%E5%BB%BA%E8%A7%86%E9%A2%91%E8%AE%BE%E5%A4%87%E7%9A%84%E5%8E%9F%E5%9B%A0%E5%90%97%EF%BC%9F%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82csi%20%E5%B7%B2%E5%8A%A0%E8%BD%BD%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%20%2Fdev%2Fvideo0%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1276891%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1276891%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E7%BB%B4%E5%85%8B%E5%A4%9A%EF%BC%8C%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%20%20%20%E6%88%91%E5%8F%AA%E6%9C%89%20video0%EF%BC%8C%E5%AE%83%E5%9C%A8%20isi%20%E8%AE%BE%E5%A4%87%E4%B8%8A%EF%BC%8C%E6%B2%A1%E6%9C%89%20csi%EF%BC%8Cv4l-ctl%20%E2%80%94%E2%80%94%20%E6%89%80%E6%9C%89%E4%BA%BA%E9%83%BD%E8%AF%B4%E5%AE%83%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%98%AF%20mxc-isi-m2M%EF%BC%8C%E6%89%80%E4%BB%A5%E5%B0%BD%E7%AE%A1%E5%81%9A%E4%BA%86%E5%B7%AE%E4%B8%8D%E5%A4%9A%E5%9C%A8%20imx8mp-evk.dts%20%E4%B8%AD%E6%89%80%E5%81%9A%E7%9A%84%E4%BA%8B%E6%83%85%EF%BC%8CCSI%20%E8%AE%BE%E5%A4%87%E6%B2%A1%E6%9C%89%E6%98%BE%E7%A4%BA%EF%BC%8C%E4%BD%A0%E7%9A%84%E8%AE%BE%E5%A4%87%E4%B9%9F%E6%B2%A1%E6%98%BE%E7%A4%BA%E3%80%82CSI%20%E8%AE%BE%E5%A4%87%E4%BD%8D%E4%BA%8E%200x32e40000%20%E4%B8%8A%EF%BC%8Cisi%20%E8%AE%BE%E5%A4%87%E4%BD%8D%E4%BA%8E%2032e00000%20%E4%B8%8A%EF%BC%8C%E8%BF%99%E5%B0%B1%E6%98%AF%E4%BD%A0%E5%9C%A8--list-devices%20%E4%B8%AD%E7%9C%8B%E5%88%B0%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E5%A6%82%E4%BD%95%E8%AE%A9%20csi%20%E8%AE%BE%E5%A4%87%E5%87%BA%E7%8E%B0%E3%80%82dmesg%20%E6%98%BE%E7%A4%BA%EF%BC%9A%3CBR%20%2F%3Emxc-mipi-csi2-sam%2032e40000.csi%EF%BC%9Alanes%201%EF%BC%8Chs_settle%EF%BC%9A22%EF%BC%8Cclck_settle%EF%BC%9A0%EF%BC%8Cwclk%EF%BC%9A1%EF%BC%8Cfreq%EF%BC%9A5000000000%EF%BC%88%E6%88%91%E7%9A%84%20dts%20%E6%9B%B4%E6%94%B9%E4%BA%86%20settle%20%E7%9A%84%E5%80%BC%EF%BC%89%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E7%9C%8B%E8%B5%B7%E6%9D%A5%20csi%20%E8%AE%BE%E5%A4%87%E5%8A%A0%E8%BD%BD%E6%AD%A3%E5%B8%B8%EF%BC%8C%E5%AE%83%E5%8F%AA%E6%98%AF%E6%B2%A1%E6%9C%89%E5%88%9B%E5%BB%BA%20videox%20%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%E8%BF%99%E6%9C%89%E7%82%B9%E7%A5%9E%E7%A7%98%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1247872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1247872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%20dts%20%E6%96%87%E4%BB%B6%EF%BC%9F%E6%82%A8%E5%B0%9D%E8%AF%95%E8%BF%87%E4%BD%BF%E7%94%A8%20imx8mp-evk-basler-ov5640.dtb%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1237589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1237589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9B%AE%E5%89%8D%E4%BD%BF%E7%94%A8%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E6%98%AF%205.4.47%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9C%89%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%81%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1237052%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20MIPI-CSI2%20Problems%20in%20custom%20camera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1237052%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%88%9A%E6%94%B6%E5%88%B0%E6%88%91%E7%9A%84%20imx8mp%20%E6%9D%BF%EF%BC%8C%E9%A6%96%E5%85%88%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E4%BD%A0%E7%94%A8%E7%9A%84%E6%98%AF%E4%BB%80%E4%B9%88%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%20%E7%89%88%E6%9C%AC%EF%BC%9F%E8%AE%A9%E6%88%91%E9%87%8D%E7%8E%B0%E8%BF%99%E4%B8%AA%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
